MG ZR 2006 Central Locking Module Problem - MG-Rover.org Forums
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 24-02-2012, 16:56   #1
howy
Car: MG ZR
can anyone help please, i have an MGZR 2006, i have been told that the central locking module, has gone and i need a new one. The car locks off the fob, but does not open the doors. I can Open the drivers door only with the key, the boot will open with the fob. The passenger door is deadbolted, it will not open even from the inside. has anyone any ideas how to fix this problem thankyou
howy is offline   Reply With Quote Quick reply to this message
Old 24-02-2012, 18:18   #2
starlight14
Car: MG ZR
This sounds like a relay has failed in the BCU (coil has gone open circuit). easy to fix if you have a relay and are okay with a soldering iron and sucker.
The pektron unit is ~ 125 from pektron over the internet. This will need programming with the fobs but you will require the fob bar codes to do this.
Check with your local dealer.
starlight14 is offline   Reply With Quote Quick reply to this message
Old 24-02-2012, 20:13   #3
technozen
Mmmm....Rover..
technozen's Avatar
Car: 200vi & Freelander XEDi
Sounds like both the central locking relay and the deadlock relay have failed.
If you need replacement relays or need it repaired drop me a PM.
__________________
I offer FREE engine/alarm diagnostics and fob coding (incl. Pektron fobs) to mg-rover.org Supporters - details here.
Fob not working? Common faults and fixes here.
Pektron BCU/SCU Faulty? This may be of some help. Full SCU programming and repair services available.
Discounted SCU/BCU Full Relay Replacement Service - only for Supporters - details here
Replacement relays for the Pektron SCU available - .org Supporters buy 4, 5th is free - PM for details.
technozen is offline   Reply With Quote Quick reply to this message
Old 08-03-2013, 15:55   #4
xX_o2_Xx
Temporary Seller
Car: MG ZT-T
My friend bought a zr but it has a weird issue.
When the drivers door is open all the locks spazz. Constantly lockimg and unlocking.
Whwn its shut everything is fine again.
As a temporary solution I disconected the pin button which detects whether the door is open or closed.
This has stopped the locks spazzing but now when he unlocks the car with fob it locks almost immediately after.
Can still get in and use car.
Its a 53 plate with the round fob.
Also the intermitent wiper function doesn't work
xX_o2_Xx is offline   Reply With Quote Quick reply to this message
Old 08-03-2013, 17:23   #5
technozen
Mmmm....Rover..
technozen's Avatar
A faulty drivers door lock is most likely the cause of the central locking problem and a relay in the SCU has failed which is the cause of the intermittent wiper problem.
__________________
Old 08-03-2013, 18:51   #6
xX_o2_Xx
Temporary Seller
Car: MG ZT-T
Is their anyway to test the theory?.
Tried unplugging the drivers door lock and it made no difference
Old 08-03-2013, 21:38   #7
Rovermgrob
Car: Rover 200 (89-95)
Hi i am a mg rover speclist what has gone wrong with your zr is the SCU ( security contol unit) has gone you will have to go to your nerest mgrover speclist to get the unit your will need to have two new plips programmed as wee and that will cost about 700
Rovermgrob is offline   Reply With Quote Quick reply to this message
Old 10-03-2013, 00:19   #8
stiggs
Car: Rover 25
Did you take your car to mantles in biggleswade? I saw a red zr there with white wheels that had exactly the same problem
stiggs is offline   Reply With Quote Quick reply to this message
Old 10-03-2013, 00:39   #9
technozen
Mmmm....Rover..
technozen's Avatar
The drivers door latch contains two switches which tell the SCU if the door is opened or closed.
You can test the switch signals on a Black/Pink and Black/Orange wires at the lock wiring.
There is no need to go down the ridiculously expensive route of fitting a new SCU and new fobs.
Most SCU's can be repaired and even if the board is scrap (rare) the data from the original can be copied into a used board to create a clone.
__________________
Old 10-03-2013, 00:41   #10
SR4SLH
Ten Pin Bowling Champion!
Car: 2006 mk2 MgZS, MG ZR+ No.2029, MG ZR 105 ,Rover 200VI Rep:■■■■■■
i have central locking modules for sale
S
SR4SLH is offline   Reply With Quote Quick reply to this message
Old 10-03-2013, 00:48   #11
xX_o2_Xx
Temporary Seller
Car: MG ZT-T
The old owner unplugged the drivers door loom to stop the risk of being loked in if the door lock screws up.
It still did it.
The only thing that stops it doing it is removing the screw from the door pin as I believe this cuts the earth from the buttons circuit?
It leads me to think their is a issue with the earthing or maybe even tailgate wiring split and touching the chasis?.
I'll take a video next time my friend brings the car over
S
I should have spares in the shed if i can find them .
Thanks anyway
Old 10-03-2013, 00:50   #12
xX_o2_Xx
Temporary Seller
Car: MG ZT-T
Their also seems to be an issue with the imobiliser.
Normally it should pick up the fob near the car when the ignition is on?.
This doesnt, often when the key is turned the car makes a sound. Then when the unlock button is pressed again it dissarms the imobilser.
Old 10-03-2013, 00:54   #13
SR4SLH
S
Let me know
S
Old 10-03-2013, 03:02   #14
technozen
Mmmm....Rover..
technozen's Avatar
The ground connection for the door latch is wired on the door loom into the main loom, there are no mechanical connections in the door to chassis.
__________________
Old 10-03-2013, 07:19   #15
xX_o2_Xx
Temporary Seller
Car: MG ZT-T
Sorry. I mean the pin thing which is part of the chasis which detects when the door is open.
To me it seems the fault is revolving around that
Old 10-03-2013, 07:23   #16
xX_o2_Xx
Temporary Seller
Car: MG ZT-T
Let me know
S
Cheers will do
mg zr central locking problem mic5274 MG ZR / Rover 25, 200 & Streetwise 4 21-10-2011 12:07
mg zr central locking problem hibee zr MG ZR / Rover 25, 200 & Streetwise 5 09-12-2010 15:45
MG ZR Central Locking Problem. Jim2402 MG ZR / Rover 25, 200 & Streetwise 12 10-01-2007 22:05
MG ZR - Problem With Central Locking tommyg2688 MG ZR / Rover 25, 200 & Streetwise 4 22-01-2006 19:47
