Cooling system bleeding point - MG-Rover.org Forums
Old 01-03-2012, 11:03   #1
athorpe
Guest
Posts: n/a
A mildly successfull day today,
The reason for losing a small amount of water has been found, the bad part is the radiator is weeping along one of the tanks, the better news is its not a water pump or headgasket or something major (though it doesnt look fun to get the radiator out)
When it comes to refilling (and topping up)
Is there a bleed vavle anywhere in the cooling system when refilling, or is it self bleeding ?
Its a 2ltr petrol
  Reply With Quote Quick reply to this message
Old 02-03-2012, 16:58   #2
Luke MG ZT
Car: MG ZT
Hi,
If its the same as my ZT 1.8t its just in front of the battery under the air inlet pipe, you have to push the air pipe out the way and its a small bolt head (8mm i think) attached to the top of one of the coolant pipes you have to undo the bolt to bleed. (make sure the have the heaters on full/hot when bleeding) once done if your heaters dont get hot then you still have air in the system so a repeat bleed will fix. Good luck
Luke MG ZT is offline   Reply With Quote Quick reply to this message
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Bleeding cooling system knight_templar MG ZT / Rover 75 (Sponsored by Rimmer Bros) 5 22-02-2011 17:40
Bleeding cooling system alphonso MG ZS / Rover 45 & 400 0 18-07-2009 20:52
Bleeding the cooling system davy800 MG ZR / Rover 25, 200 & Streetwise 11 12-12-2007 10:44
Bleeding cooling system!! colind9 Diesel Forum! 2 27-11-2007 17:23
Bleeding cooling system! Tbird_885 Others 8 04-08-2005 18:00
