Cooling fan doesn't stop - MG-Rover.org Forums
Old 02-03-2012, 19:47   #1
steph30
Car: MG ZS
Hi gents,
Since the last very cooled period in France I have a problem with my cooling fans.
Symptom:
- when I switch on ignition (when instrumental panel in on) and when air conditioning ventilation is at least set to speed 1, then cooling fans are running at low speed. When I switch off the ignition then the cooling fans stop
- when I switch on ignition (when instrumental panel in on) and when air conditioning ventilation is off, then cooling fans are not running at all
I am a bit lost, I don't understand how the air conditioning ventilation can affect the cooling fans.
Any idea how to troubleshoot?
Stéphane
steph30 is offline   Reply With Quote Quick reply to this message
Old 03-03-2012, 06:24   #2
MARCOVH
I'LL BE BACK!!!!!!!!
MARCOVH's Avatar
Car: Rover 45
Talking
Originally Posted by steph30 View Post
Hi gents,
Symptom:
Stéphane
They always run with the aircon on
__________________
MAKE IT BEFORE YOU BREAK IT!!!!!!!!!!!!!
MARCOVH is offline   Reply With Quote Quick reply to this message
Old 04-03-2012, 18:44   #3
steph30
Car: MG ZS
Maybe.
But in my case aircon is off.
Only ventilation is on (manual mode).
Do I have a problem with my car?
Old 04-03-2012, 18:56   #4
Talkingcars
Car: MGZS180,MGZR160,MGF VVC,MG Maestro T16, Rover 111
The secondary cooling fan will run if the aircon is on and the car is stationary or at low speed.
The main cooling fan will run if the ECU is getting an incorrect signal or no signal from the coolant tempreture sensor, there are 2, 1 just reads tempreture and the other is for switching the fan but I am not sure which is which.
Anyway, the fan will run if there is a problem with the sensor.
Can you get the computer read with T4 or OBD2?
Talkingcars is offline   Reply With Quote Quick reply to this message
Old 05-03-2012, 07:21   #5
MARCOVH
MARCOVH's Avatar
Car: Rover 45
Talking
The one with the two wires goes to the ECU this one
http://www.rimmerbros.co.uk/Item--i-GRID003183
nr 13,the one with one wire goes to the temp gauge.They're in front off the engine bay on the coolant elbow coming out off the engine, where the coolant pipe is mounted on
__________________
Old 05-03-2012, 21:17   #6
steph30
Car: MG ZS
Ok then
I will start my work on this sensor and I will let you know.
Old 06-03-2012, 04:34   #7
MARCOVH
MARCOVH's Avatar
Car: Rover 45
Talking
Ok then
When you're quick you can change the temp-sensor without spilling any coolant (Cold engine offcourse)
__________________
Old 13-03-2012, 17:01   #8
steph30
Car: MG ZS
I just receive the new spare sensor I will try it.
But after a check, I saw that air con is running everytime even if selected off (manual mode on mk2).
Maybe the compressor clutch remains engaged whatever is the air con mode.
How can I check it?
Old 17-03-2012, 13:41   #9
steph30
Car: MG ZS
With the new sensor the fault remains.
With my diag tool, I read P0118 Engine Coolant Temperature Circuit High Input.
Do you know where does the problem come from?
Thanks for your help
Cooling fan and a/c fan 2nd scale from scratch..? nikolas MG ZR / Rover 25, 200 & Streetwise 6 22-05-2011 22:49
Cooling fan or mind of its own fan geoff1 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 24 19-02-2011 22:17
Fan wont stop on CDTi FerryScoob MG ZT / Rover 75 (Sponsored by Rimmer Bros) 7 24-01-2009 09:48
Rover 75 Cooling fan doesn't stop tomsu MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 21-09-2007 03:31
HELP... my fan won't stop... katiesue MG ZT / Rover 75 (Sponsored by Rimmer Bros) 7 21-07-2006 11:44
