kv6 cam timing issues - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Model Specific Forums > Land Rover
Old 02-03-2012, 19:14   #1
lilblakcooper
Car: freelander kv6
Exclamation kv6 cam timing issues
Hi everyone, I have just done the headgaskets on my freelander with a bit of help from a friend, When we rebuilt it and fired it up it was running on three maybe four cylinders and the front cat started to glow red at that point i switched the car off, rechecked the cam timing , did a compression check all ok.
Is it possible to put the camshafts the wrong way around (inlet in exhaust) type of scenario.
We did some live data on it and no's 1,3,5 all registered missfires..
any guidence would be gratefully recieved.
lilblakcooper is offline   Reply With Quote Quick reply to this message
Old 02-03-2012, 20:46   #2
418sld
Car: '02 Volvo V70 + '75 850 Mini
Did you use the proper timing tools or just wing it with tippex?
418sld is offline   Reply With Quote Quick reply to this message
Old 03-03-2012, 07:09   #3
lilblakcooper
Car: freelander kv6
no mate i actually bit the bullet and bought the proper timing kit.
Just had another thought, does anyone know how to distinguish the inlet cam from the exhaust cam?
does the rear head inlet cam have a cam sensor pick up on? as the inlet cam in the front head from looking at it has a half cast ring where the cam sensor picks up on! should this be a reluctor type set up and the two inlet cams has got mixed up while being on the workbench?
Old 03-03-2012, 14:55   #4
lilblakcooper
Car: freelander kv6
ok i think i have sussed it out, is it possible to time up the engine with one of the heads with the cams 180 degrees out? i mean fuelling as the piston goes down therefore pushing unburnt fuel mix into the exhaust.
then is it feasable to remove the belts move the offending cams 180 round then reinstall the belts?
Old 03-03-2012, 15:32   #5
418sld
As long as the tool locked on correctly then the timing should be ok. I can't see the cams being different. 1,3 & 5 are all on one bank (can't remember which) so is it something daft like wiring switched around? If not recheck valve timing.
Old 06-03-2012, 20:01   #6
lilblakcooper
Car: freelander kv6
thanks for your replys and i'm just glad its sorted now.
Timing up a KV6...? TommyV6 MG ZS / Rover 45 & 400 1 16-08-2010 19:31
ZS180 KV6 Snapped-off exhaust cam timing lugs Dr Dave MG ZS / Rover 45 & 400 12 06-06-2010 06:08
KV6 issues if any? bertiebowser MG ZS / Rover 45 & 400 3 21-01-2009 20:52
Rover kv6 timing and cam belt change tools Hippo Rover 800 2 24-11-2008 05:56
KV6 cam timing re5rotary Others 10 25-09-2005 09:01
