#1 |
Car: MG 6 GT
Experiences so far
Hi All,
I have posted on here within other threads sharing my on-going experiences with the new MG 6. Have owned it from new on 61 plate, from September last year and with 8.8k on the clock as of this morning. So i'm starting to build up a good impression of what I like and do not like about the car. My experience with MG has been fantastic. The initial car that I bought failed it's PDI, something to do with the EMS. As result this had to go back to MG for fault finding and a replacement was sent. Great! They also compensated me with silverstone tickets and the dealers MG 6 magnette until mine was delivered and ready. 2 weeks later, it was here PDI'd and ready to go. Since then I have used the car daily, I find the quality on the inside of the car to be ok, it's not too bad. However, the sound proofing isn't good at speeds, my partners 10 year old vw and my 5 year old focus was is much better in this area. Sadly, its not been fault free. With the first problems appearing around 2.5 to 3k with random creaky noises on the steering. The dealership wasn't wasn't able to find a fault and the problem went away. Still to this day it does it on occasions, more so when its been cold and wet. At around 6.5-7k I started getting a low coolant alarms, levels appeared to be fine, so it went back in and had a new sensor. They also ordered me a new reversing camera due mine being constantly fogged. As of last week (around 4 weeks since it has its new sensor) the low coolant alarm returned, now the car is due to go back in next week for the new camera, so I have also informed them of this. They now suspect it could the float sticking. The problem only occurs after the car has been standing over night. It has also developed a clutch squeaking/spring type noise, which I need to inform them off. It mat seem picky, but you don't expect these things on a new car. Last night I took some photos of the levels, the first one after a I had been on a run, and the second one this morning around 30 mins ago. I'm not liking what I see, and this somewhat concerns me. The car is a pleasure to drive, would be even better without the problems though. I will keep this thread updated as and when I get feedback Photos: Level after run Level this morning Last edited by danemeuk; 06-05-2012 at 10:58. |
| Sponsored Links | |||
Advertisement | |||
#2 |
Moderator
Looks like the coolant needs topping up. It's right that the coolant level is higher immediately after a run, the hot coolant has expanded (hence the name expansion tank) and that's totally normal. I'd be more worried as to why the coolant level is low.
#3 | |
Car: MG 6 GT
I don't want to jump to any conclusions on the matter, as it's going in on Tuesday it is best for them to sort it out. As long as they can tell me, A) why the levels have dropped, and B) what they have done to fix it. |
#4 |
Car: Other Manufacturer
Good to see feedback like this, I hope you get your problems sorted. At least we now know the car isn't perfection, not many cars are.
#5 |
Car: Saab 93 aero sportwagon ttid 180 & mg zr trophy se
Any pics of he whole car.....I don't we have seen that yet?
#6 |
Car: MG 6 GT
#7 |
Location: Bromley, Kent Car: Rover 111SLi and MG Metro 1300
My pal had a 60 reg [new shape] VW Polo coutesy car whilst the insurance claim went through when someone rear ended his Metro GTa. The coolant level on that was under minimum. It wasn't ours and we didn't touch it. The car wasn't much more than 6 months old at the time.
No matter what brand, cars aren't what they used to be in the late 90s early 00s... |
#8 | |
Car: MG 6 GT
#9 |
Location: Bolton Car: Mk1 Special Edition and Nightfire Tickford who's called Ruby
I'd be concerned if the coolant wasn't the correct colour more than the level dropping. Likely that there is a pipe loose somewhere and that's allowing an escape of coolant. How many times have you topped it up since you got it ?
My 800 needs topping up quite often but I know it's a leaky water pump or pump gasket so I'm not concerned over head gasket problems (being an M-series and all ). |
#10 | |
Car: MG 6 GT
#11 |
Looking forward to your pictures tommorow.
#12 | |
Location: Birmingham Car: scimitar ss1,1800 ti MG6 Magnette TSE
The PAS on the MG6 is hydraulic, I have owned other cars in the past with this type of assistance and when the fluid is cold they do whine. I am pleased to say I have still no issues, just had a weekend away, done around 250 miles averaged about 38 mpg. Last edited by littlechicken; 06-05-2012 at 21:30. |
#13 | |
Car: MG 6 GT
I'm famliar with the PAS wine, and it's not the whine. This sounds like a creak of ball joint sort of creak. It's totally random, and it doesn't do it for the techs at the dealers. In regards to the coolant, I've had some feedback from some people about some clips not being secured correclty duirng the UK assembly. They said my pictures may confirm this, so I will feed this back on to the dealership and they can take it from there. Off to wash it soon, so I will take some snaps and post them it. |
#14 |
Car: .
I've also heard a creak on full lock at low speeds while manoeuvring. Just a split second noise. My parents Nissan used to do it as well from new so I haven't really taken much notice. I might mention it when it goes in for a service in October. It's rare and infrequent as you say.
#15 |
Location: Pwllheli North Wales Car: MG6 GT TSE , MG TF 135
Ive had the coolant expansion bottle cap replaced on mine as that was the cause of the level dropping (a very small amount) other than that its fine after 11500 miles
#16 | |
We have been spoiled by electric power assistance! I would not have thought it was the clip if the level had not reduced previously, hence the suggestion of the cap, I had a similar problem with the MG ZR. |
#17 |
MG3 in ? weeks!
Did you know that there is an accepted issue with the float in the coolant tank where there is a factory-approved improvement? Talk to your dealer or look at the MG6 Register on Facebook.
__________________
MG. A well fly set of wheels, bro. |
#18 | |
Car: MG 6 GT
Not washed the car, but got some pics so I will add them once I have transfered them off my phone.
#19 | |
Car: MG 6 GT
As for the steering, well they have had a look at it and can't find anything wrong. So I'm happy with that, it doesn't do it often. As long as it doesn't become reoccuring I'm not too fussed about it. |
#20 |
Moderator
Top up your coolant.
Seriously, if you're driving around with a lack of coolant you're just asking for trouble. Just tell the garage how much you've had to add whe you take it back to them.
| Bookmarks |
| Thread Tools | |
| Chipping experiences | PorKa200Is | Others | 12 | 20-06-2004 19:06 |
