Petrol in diesel 400, how to drain the tank? - MG-Rover.org Forums
Old 23-05-2012, 10:26   #1
SDI200
Car: Rover 400 GSDi, LandRover S3 with turbo PERKINS! and a Toyota Yaris for the missus!
Send a message via MSN to SDI200
My car, 98' 400 GSDi, has 5 litres of petrol in a nearly empty tank of diesel!! Long story.... The car has not been started since the petrol was added on the drive at home. How can I completely drain the tank? I don't want to run the pump up And get petrol in the system to empty so is sythoning my only option?
SDI200 is offline   Reply With Quote Quick reply to this message
Old 23-05-2012, 10:37   #2
p_b82
Car: ZS+ 170TD
tbh i would probably just fill the tank with proper derv and not worry about it..... and then keept it topped up as sson as it drops to a 1/4 or so.... for a bit.
other option would be to unplug the fuel filter and fit something to draw the fuel out from there.... (the priming bulb would work but would take forever)
p_b82 is offline   Reply With Quote Quick reply to this message
Old 23-05-2012, 10:40   #3
gibbzy2k1
Car: 820 Vitesse*RIP, MG ZS+ 115, 825 Sterling Coupe *RIP, 825 Sterling Saloon, Subaru Legacy 3.0 specB
Send a message via MSN to gibbzy2k1
I put a gallon on petrol in the derv when I first bought it about 2 years ago. I filled it with derv and ran it. I kept it above 1/2 a tank for about 3 - 4 months and then changed the filter while I was doing a service. Had no problems with the car since.
Your could drop the fuel tank to empty it, the thought crossed my mind at the time as the RAC wanted 200 to do it.
gibbzy2k1 is offline   Reply With Quote Quick reply to this message
Old 23-05-2012, 10:48   #4
Macey
Car: MG ZT CDTI, MGF & Triumph Sprint ST 1050
It shouldn't be a problem. Just fill up with diesel and change the filter after you've used a couple of tanks. You'll find that plenty of us have done similar without any issues.
Macey is offline   Reply With Quote Quick reply to this message
Old 23-05-2012, 11:15   #5
jdhturner
Car: Rover 400 (95-99)
A few years ago, Top Gear tested the effects of incorrect fuelling...
My recollection may be wrong, but I think both cars survived unscathed - that's petrol in a diesel and vice-versa.
Five litres is less than 10% if you fill it to the brim - it's hard to see that making much difference. Indeed, derv mixes vary between summer and winter anyway - what you'll have is probably more or less winter diesel in summer.
jdhturner is offline   Reply With Quote Quick reply to this message
Old 23-05-2012, 14:20   #6
Magicalwill1
Car: R45 TD Heavily modified, wolf in sheep's clothing
1st day i had my 45 td i put 20lts of petrol in a empty tank, payed for it and then filled it with 20lts of derv and 500ml of 2 stroke oil. Car started and ran all tho it smoked a bit and ran the tank down to empty and put derv in it again, car seemed to go better that next week lol - maybe it cleaned out some carbon?
Magicalwill1 is offline   Reply With Quote Quick reply to this message
Old 23-05-2012, 15:14   #7
gibbzy2k1
Wink
I remember mt uncle put the wrong fuel in is Renault Savanna years ago and it completely screwed it up. ECU errors etc I believe. But I know plenty of people who have done it. Though every RAC \ AA type person says its really, really bad and you should pay them around 200 to get it sorted properly...
Old 23-05-2012, 16:11   #8
minesarover
Location: Mid Glamorgan.........@@@@@@@ SYKES PICKAVANT ACR4 IMAP & IKEYS @@@@@@@
Car: Rover 420 sdi ,Mitsubishi Shogun 2.8 LWB,BMW Z3, Ford Transit, MG ZSTD
If you do want to empty the tank you can access it from the boot area above.
minesarover is offline   Reply With Quote Quick reply to this message
Old 23-05-2012, 16:36   #9
Chrisund123
Car: 45 2.0 Diesel
No you can't.
Chrisund123 is offline   Reply With Quote Quick reply to this message
Old 23-05-2012, 18:01   #10
minesarover
Thats a damn shame ...you can on the 420....disconect the primer bulb and stick a drill pump on it.
Old 23-05-2012, 18:07   #11
Chrisund123
Car: 45 2.0 Diesel
It's incredibly annoying; you remove the access plate to be greeted with the top of the tank and no useful things in reach
Have to drop the tank on the derv to get to anything.
Old 24-05-2012, 09:49   #12
p_b82
Car: ZS+ 170TD
if you put petrol in a commaril engine you will muller then - but our old L-series is a bit agricultural ; and should take mild dose of petrol in its stride
Old 24-05-2012, 14:14   #13
DMGRS
Discount MG Rover Spares (Formerly Mattyprice4004)
DMGRS's Avatar
Car: MG ZT-T+ CDTi Auto
Send a message via MSN to DMGRS
Dr Dave did an engine swap on a 220SD that someone had put petrol in, it melted a piston if I remember correctly.
Water it down with a lot of diesel first, but you should be OK
DMGRS is offline   Reply With Quote Quick reply to this message
Old 24-05-2012, 19:36   #14
SDI200
ill have to drop the tank over the weekend
Old 24-05-2012, 19:53   #15
jdhturner
Before you go that far, try syphoning it out with a length of garden hose - but the consensus seems to be that even that much effort isn't worth it for such a small amount of petrol. (I've no idea if it's possible to syphon fuel out to such a low level, but it's got to be worth a try.)
Old 05-06-2012, 17:05   #16
russpolly
Car: MG ZS
Wrong fuel
Simply fill it to the brim with the correct fuel and run it, you won't do it any harm. Incidentally the practice of adding petrol to the fuel for diesel engines is not that unusual as it is a practice that is sometime used in extreme weather conditions to stop the diesel fuel from waxing (and thereby ceasing to flow) on heavy plant and cranes.
russpolly is offline   Reply With Quote Quick reply to this message
Old 06-06-2012, 00:33   #17
fathead431
Car: Rover 45
Send a message via Skype™ to fathead431
http://www.youtube.com/watch?v=b5xhPAundL4
fathead431 is offline   Reply With Quote Quick reply to this message
Old 06-06-2012, 07:39   #18
johnandchris
Car: Rover 75 1.8t Auto saloon
Did the same last month, put 15 petrol in my 75 diesel.
Filled up the rest with diesel, ran fine.
Dont drop the tank, just go with it.
John
johnandchris is offline   Reply With Quote Quick reply to this message
HELP ! need to drain a petrol tank ! WaterfordGary Republic of Ireland 3 11-05-2012 15:59
How to use pump to drain petrol tank DaveR2000 MG ZR / Rover 25, 200 & Streetwise 4 07-06-2010 05:07
how do you drain petrol from diesel tank?? paulhouston74 Diesel Forum! 8 08-01-2010 16:06
How does one drain the diesel tank? fenlander MG ZS / Rover 45 & 400 6 03-01-2009 14:39
Need 2 drain petrol from rover 25 fuel tank.. any help Dymes MG ZR / Rover 25, 200 & Streetwise 2 30-06-2007 21:20
