2003 MGZR central locking problems - Page 2 - MG-Rover.org Forums
Old 18-06-2012, 11:50   #21
rovermarksy
Car: Rover Streetwise
It sounds like you need to replace the CL relay in your pektron SCU, which is behind your glovebox. All you need is here:
http://forums.mg-rover.org/showthread.php?t=384938
tecnozen is indeed the man for the job.
rovermarksy is offline   Reply With Quote
Old 18-06-2012, 13:00   #22
leeleecoggan
Car: MG ZR td 2003
does that apply to my model it says in technozen's post that its for facelift models??
leeleecoggan is offline   Reply With Quote
Old 18-06-2012, 13:02   #23
Roverlike
As I understand you have square fob and by that 5AS alarm type, not Pektron type as you would have round fob with logo in the middle, which is for facelift models.
Roverlike is offline   Reply With Quote
Old 18-06-2012, 13:21   #24
leeleecoggan
Car: MG ZR td 2003
so the link above does not include my vehicle!?
Old 18-06-2012, 13:22   #25
Roverlike
Above link covers Pektron systems.
Old 18-06-2012, 13:32   #26
leeleecoggan
Car: MG ZR td 2003
any ideas where the a5s alarm system is located? and possible any pics of what it looks like?
Old 18-06-2012, 13:37   #27
Roverlike
Here you can see how it looks: http://www.bba-reman.com/content.asp...control_module
Location could be tricky. I am not sure if alarm was placed on another location in year 2003 cars.
Usually 5AS system is behind desh on drivers side, but it could be also behined glove box, or behined central cosole.
Old 18-06-2012, 17:45   #28
L33t
Car: MG ZR 120
new battery installed in the fob but no difference which kinda makes sence if the key wont activate the central locking then theres no chance of the fob doing it! there must be a fault between the central locking controller (whereever that is) and the drivers door!
Have you reprogrammed the fob after changing the battery?
I heard something about having 30 second to change it or you have to reset it by holding the unlock button for a few second?
I'm not sure if this is true because I have only recently got my ZR also.
L33t is offline   Reply With Quote
Old 18-06-2012, 17:56   #29
technozen
Mmmm....Rover..
technozen's Avatar
Car: 200vi & Freelander XEDi
The 5AS is mounted horizontally above the pedals. Remove it, open it up and see if the circuit board is burnt up.
__________________
I offer FREE engine/alarm diagnostics and fob coding (incl. Pektron fobs) to mg-rover.org Supporters - details here.
Fob not working? Common faults and fixes here.
Pektron BCU/SCU Faulty? This may be of some help. Full SCU programming and repair services available.
Discounted SCU/BCU Full Relay Replacement Service - only for Supporters - details here
Replacement relays for the Pektron SCU available - .org Supporters buy 4, 5th is free - PM for details.
technozen is offline   Reply With Quote
Old 18-06-2012, 19:34   #30
SeanZR
Car: ZR
just to let you know lee. i have a spare matching 5as unit ,transponder and fob here. if you wanna give me a shout out i can swap them for you and give it a go. shure you're pretty close to where i live anyway.
btw technozen do i need the matching ecu as well. its just the fob and the 5as came out of a 211i. would this make a difference or do you need the matching ecu for the 5as and fob etc to work
SeanZR is offline   Reply With Quote
Old 19-06-2012, 07:25   #31
leeleecoggan
Car: MG ZR td 2003
thanks for the advice, if its burnt can it be fixed? can you supply the parts or will i need to send it to you? cheers lee
Old 19-06-2012, 09:45   #32
technozen
Mmmm....Rover..
technozen's Avatar
With a burn up it is impossible to say if it can be repaired until the board can be inspected, if it can't be repaired a replacement can be cloned using the data taken from the original.
__________________
Old 19-06-2012, 10:54   #33
leeleecoggan
Car: MG ZR td 2003
can i use a friends fob and box out of his spares kit in the meantime or will it not work?
Old 19-06-2012, 11:21   #34
Roverlike
If you have original alarm box and engine ECU then you can not use friends box as it needs to be paired with your ECU.
Old 19-06-2012, 11:45   #35
leeleecoggan
Car: MG ZR td 2003
will this fix my problem if it does turn out to be the 5as unit? cheers
http://www.ebay.co.uk/itm/ROVER-TURB...#ht_538wt_1344
Old 19-06-2012, 11:51   #36
Roverlike
There is no word which type of ECU this is. It must be suitable for your car, and you can not know that just from this ad without exact number stated on the ECU.
The best way would be that this ECU has the same type number as yours, as in that case it could be suitable, and could fix your problem if it turns out to be the 5as unit.
Old 19-06-2012, 12:23   #37
technozen
Mmmm....Rover..
technozen's Avatar
Check the 5AS first, it may not be the cause of the fault.
__________________
Old 19-06-2012, 23:20   #38
steve0011
Car: MG ZR
i have the exact same problem with the ignition on the immobilizer bleeps and flashes on the dash pressing the fob deactivates immobilizer and the car starts. tonite i powered up the locking system directly using a battery and the doors/boot lock and unlock just fine.
does the key in the drivers door normally activate the central locking? or just open the drivers door only?
77
i have a spare 5AS and fob is cloning it a diy job?
i checked the boot loom and every single wire has insulation worn off so the 5AS more than likely fried
my final question is.... do i carry on trying to fix this or is there a after market system i could use?
steve0011 is online now   Reply With Quote
Old 20-06-2012, 06:36   #39
Roverlike
77
Key in drivers door do normally activate central locking. I would assume that if you can not activate C/L by fob, you will not be able to do it by key also as 5AS unit might be "fried".
It would be wise to take out 5AS unit for inspection to see if it suffere electrical damage and is 5AS really the problem.
5AS cloning is not DIY job. You need appropriate tools for such thing.
In case that 5AS is the culprit, then will you go aftermarket C/L way or send 5AS for cloning is up to you. Both ways can be done.
I would assume that 5AS cloning is easier as you have all in place just swap is needed. In case of aftermarket one you would need to play with wires and existing loom.
Old 20-06-2012, 09:09   #40
steve0011
Car: MG ZR
thanks for thr reply mate.
i have a spare 5AS does not work as its not matched to the ECU. however, i could use one to repair the other depending on damage. i will pop it open later.
only got the car a few days ago apart from this issue its quite sound, a little scruffy here and there but not bad for the money (£300 for a 2003)
You may not post replies
central locking 2003 R25 bandor MG ZR / Rover 25, 200 & Streetwise 22 12-01-2012 18:24
streetwise 2003 - central locking and blown fuse spicecat MG ZR / Rover 25, 200 & Streetwise 1 14-07-2011 18:07
Noisy Central locking on MGZR folkswagon MG ZR / Rover 25, 200 & Streetwise 17 29-01-2011 10:52
mgzr central locking playing up bhogalb MG ZR / Rover 25, 200 & Streetwise 1 13-05-2007 08:17
2003 ZR central locking question Sysmic Wave MG ZR / Rover 25, 200 & Streetwise 0 05-04-2006 19:34
