Engine Light On, Answer needed please! - MG-Rover.org Forums
Old 25-06-2012, 19:30   #1
ZeV
Car: 04 ZS 180 MK2
Hello all, i have 3 error codes on my MG ZS 180 at the minute, they are as follow
1.P0141 - O2 Sensor Heater Circuit Malfunction, Bank 1, Sensor 2
2.P0131 - O2 Sensor Circuit Low Volts, Bank 1, Sensor 1
3.P0171 - System To Lean, Bank 1
I'm hoping to get it sorted on thursday, but my question is, i'm suppose to be going on a long drive tomoro, about 130ish miles, will it be alright to drive in it with these fault's? it starts ok and seem's to run ok apart from the idle racing abit. Any thought's? p.s need an answer a.s.a.p or will be forced to let the miss drive me in her Suzuki Swift
ZeV is offline   Reply With Quote
Old 25-06-2012, 23:18   #2
octanejunkie
Car: MG ZT
Hmmmmm.... Sounds like some issues with bank 1 there...
The racing idle would back that up too. Weak mixture won't do valves and piston crowns any favours. It will run hot, and you may get detonation on the cylinders on bank 1.
Whilst it may feel like its running ok, the combustion process isn't occuring correctly, and you could burn a vlave or melt a piston over a prolonged journey.
With those three faults all affecting the same part of the engine, my advice would be to put a paper bag over your head and let the Missus drive. Lol!
octanejunkie is offline   Reply With Quote
Old 25-06-2012, 23:29   #3
ZeV
Car: 04 ZS 180 MK2
I just been reading about how could get to hot & damage thing's, bugger, paper bag and bad music it is then lol, cheers anyway.
Old 25-06-2012, 23:41   #4
Jon Norris
Jon Norris's Avatar
Car: MGF (Rough Luck) 1.9 supercharged K-series VVC
It all seems to point to the pre-cat lambda sensor, the reference to the heater is the sensor heater that warms the sensor from cold starting, then the lean mixture is controlled partly by the same sensor (ECU Temp sensor also when cold) once at running temp it alone adjusts fuel
__________________
MG Rover Head Gasket Mobile Repair,
£250 for VVC and None VVC K-series engines
www.roughluckracing.com
07766993717
Jon Norris is offline   Reply With Quote
Old 25-06-2012, 23:46   #5
jdhturner
Car: Rover 400 (95-99)
Engine management is not my thing, however, it seems to me that if the O2 sensor is knackered, then the "System too lean error" is meaningless.
I'm not saying it's safe to drive or it isn't, but I would hope the ECU is designed to fail safe and use a sensible fuelling policy once a fault is detected. Sensors should only be required for optimum running.
jdhturner is offline   Reply With Quote
Old 26-06-2012, 00:20   #6
Jon Norris
Jon Norris's Avatar
Standard lambda's (Narrow band lambda) opperate on 0-1v with only 3 basic signals, rich, ok and lean, as it states in the error message it points to the sensor which must have died with a set position (or resistance)and for not so serious faults the engine management light wouldn't even come on, but yeah your right the lean issue could have just been when the sensor died or gave an irratic reading because of the heater section going bang, either way it points to the sensor
MG ones are about £125, take them out of the MG box and they are stamped Bosh, if you buy a Bosh one they are only about £65
__________________
07766993717
Old 26-06-2012, 00:57   #7
ZeV
Car: 04 ZS 180 MK2
Well i'm not going to risk it either way, false reading's or not. I did go for a spin in it today and the engine temp was ok, could smell petrol a fair bit though. I ended up under the car looking for the sensor, looks easy enough to remove the actual sensor, but the cable runs off up into the engine bay and looks really hard to reach.
I'll see what the garage is going to charge me, if it's to much i'll go buy the sensor/sensors myself then they can just fit em for me.
Old 28-06-2012, 13:20   #8
ZeV
Car: 04 ZS 180 MK2
So i got the garage to put 2 new sensors in which should solve that problem but they fount another problem, something to do with a set of valves are stuck open, but they don't have much of an idea how to fix it they said lol, so does anyone here have a clue?
Old 28-06-2012, 13:27   #9
minesarover
Car: Rover 420 sdi ,Shogun LWB,Z3
What valves give us a clue ?
minesarover is offline   Reply With Quote
Old 28-06-2012, 13:38   #10
ZeV
Car: 04 ZS 180 MK2
Erm, i'm not sure he didn't give me much to go on but i'm guessing the 4 on top of one of the cyclinders lol
Old 28-06-2012, 16:11   #11
Julian.heap
We will rock you,er rocks
Julian.heap's Avatar
Car: A mazda 323f gxi :)
Send a message via Skype™ to Julian.heap
I think he is meaning the V.I.S valves are stuck open,can't be the inlet and exhaust valves inside the engine coz if they were the engine would not run or it would misfire badly.
The V.I.S (veriable intake system) valve motors are prone to sticking or malfunctioning, they can be refurbed or replaced. The open up some valves in the plenum chambers which allows more are to be drawn in, there by giving more top end power.( think thats how it works's not sure if i'm right, long time since i've worked on a ZS 180)
You can tell if the VIS motors are not working as you a rattle from the inlet manifold or a lack of power somewhere in the rev range (can't remember if it's top or bottom of the revs as i have not driven a ZS 180 in a long while.)
__________________
Is loving Mazda reliability and fuel economy,Friendly MOT tester
Julian.heap is offline   Reply With Quote
Old 28-06-2012, 16:41   #12
ZeV
Car: 04 ZS 180 MK2
lol i know that problem because i changed my inlet manifold last year, so i hope it's not broken yet again, last time the valve's actualy broke and wer rattling away, so this time if it's just the VIS motor gone, do you think i could swap them for the ones in my old inlet i still have in garage? - that or just take the ones out that are on the car and give them a good clean.
Old 30-06-2012, 16:28   #13
Julian.heap
Maybe worth trying to clean the motor's if not yeah fit the ones you have in the garage.
__________________
Old 01-07-2012, 14:20   #14
ZeV
Car: 04 ZS 180 MK2
Ok will do when i get chance, for the record the code is
P1472 - VIS 2 Valves Constantly Open
Correct me if i'm wrong but doesn't the VIS motor control a rod that open's and closes 3 valves, so how can 2 be open but not the other one?
Old 03-07-2012, 21:17   #15
sonic_160zr
Bristol Meet Founder
sonic_160zr's Avatar
Car: MG ZS 180 Mk 2 in Dark Fantasy and MG ZR Mk1 160 VVC
Send a message via MSN to sonic_160zr
Its probably refering to either the Balance or Power motor rather than the specific valves. There should be a "kick" at about 3k revs and again at 4k depending on the throttle pedal position.
If you are eating through the VIS motors as quick as it seems you are it might be worth looking into fitting an oil catch tank to stop some of the oil that is returning into the inlet becoming a grinding paste for the VIS motor mechanisms.
Check your air filter and induction system for oil. If there is a substantial amount I would deffo look at getting a catch tank fitted. A new set of VIS motors is going to set you back about £140
Cheers,
Matt
__________________
My MG ZR 160 Progress Thread Link
The April Bristol/Swindon Meet details 28/04/13 Here
MG-Rover Facebook Page Here
Check out the South West Area Section Here
sonic_160zr is offline   Reply With Quote
Old 03-07-2012, 21:46   #16
ZeV
Car: 04 ZS 180 MK2
Cheers,
Matt
I use to notice a kick, but not so much anymore, but that might be just cause i'm use to it now.
As it happens, i put a new induction kit on not long ago, a custom jobby but it does the trick and sounds wicked, didn't notice alot of oil, a little bit in the throttle pipe but nothing major, think i will either replace the VIS motors or the whole inlet again when i got the cash.
Old 03-07-2012, 23:23   #17
sonic_160zr
No need to replace the whole lot. Just replace the VIS motors and fit a catch tank. Will still a lot cheaper than replacing the inlet. I would advise getting a VIS motor indicator (a guy on theMGZS.co.uk is selling some) but he is only doing one more batch so get in there quick if you want it. Well worth the dosh as the lights will show you exactly when the motors open and close the valves so you can tell straight away if one of the motors stop working properly.
Cheers,
Matt
__________________
You may not post replies
help needed! Quick answer needed plz wolf-man Coupe 2 05-06-2009 22:04
Straight Answer Needed..... 220Deano MG ZR / Rover 25, 200 & Streetwise 9 29-05-2008 22:20
help needed, engine warning light Gregy_d MGF and MGTF (Sponsored by MGF Mania) 2 08-12-2007 10:57
very quick answer needed please Robert Others 4 27-06-2005 19:44
Quick answer needed! fireengineer Others 2 24-06-2005 09:29
