changing rear brake pads - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Ask The Gurus! - Help and Advice Forums > Diesel Forum!
Old 29-07-2012, 01:40   #1
dudarus1
Car: Citroen Dispatch Van
just a quick one really my rear brake pads are down to metal. going to be changing them tomorrow, will i need a wind back tool?
thanks
dudarus1 is offline   Reply With Quote Quick reply to this message
Old 29-07-2012, 01:41   #2
dudarus1
forgot to say its on a zr 115
Old 29-07-2012, 07:51   #3
Torkenstine
Car: Focus tdci
i used a screwdriver.
Torkenstine is offline   Reply With Quote Quick reply to this message
Old 29-07-2012, 20:42   #4
E_T_V
Car: Maestros, 200, 600, ZTT
I use a bit of flat bar. They need to be wound back in not pressed back in.
E_T_V is offline   Reply With Quote Quick reply to this message
Old 30-07-2012, 11:08   #5
Sean 220
Car: MG ZS TD 115+
Yep i just did this at the weekend, the piston has a large cross in the face, use a steel ruler or somthing to turn them clockwise.
Also remember to slacken the handbrake adjuster back to its stop (a nut on the back of the actual handbrake) and readjust once the job is finished.
If the pads really are down to metal then you will need new discs too!
Sean 220 is offline   Reply With Quote Quick reply to this message
Changing Brake pads!! mini-maddog MG ZR / Rover 25, 200 & Streetwise 6 07-10-2010 17:21
Changing brake pads on a 25. alamb200 MG ZR / Rover 25, 200 & Streetwise 6 27-11-2008 16:21
Changing the brake pads boyracer 46 MGF and MGTF (Sponsored by MGFnTFBITZ) 9 04-10-2007 14:26
changing brake pads Cyer_ricki MGF and MGTF (Sponsored by MGFnTFBITZ) 5 01-06-2006 07:57
Changing Brake Pads evian MG ZR / Rover 25, 200 & Streetwise 8 05-06-2004 17:33
