MGF Clutch problems! - MG-Rover.org Forums
Old 31-07-2012, 19:58   #1
Frasa17
Car: MGF
Question MGF Clutch problems!
Hi, i have a year 2000 mgf and its off the road at the moment due to the clutch not working, there is no pressure on the clutch at all, it sits on the floor. I have been reading through the forums on here and I can see that other people have problems, but all the solutions seem to start with 'try bleeding the slave cylinder, well i cant seem to be able to bleed anything beacuse the pedal isnt pumping any oil through when we move the pedal there is absolutly no movement on the slave cylinder, so I can only assume its the master cylinder which is mounted at the front of the car, I just need someone elses opinoin before i go and replace it and find that it wasnt the problem at all does anyone know howmuch oil should be in the sump on the master cylinder? there is no mark on it, at the moment its about half full
Frasa17 is offline   Reply With Quote Quick reply to this message
Old 31-07-2012, 20:13   #2
HarryB
Car: MGF
If one cylinder is gone you will need a set of O-rings and a clean shot of fluid, you might try by opening the master cylinder and checking the fluid level, just because it looks full from the outside doesnt mean it actually is....
HarryB is offline   Reply With Quote Quick reply to this message
Old 31-07-2012, 20:17   #3
AndyNickJenkins
AndyNickJenkins's Avatar
Car: 2001 MGF in Sienna Gold. 2008 Honda Civic Type R GT in Night Hawk Black.
It could be something as simple as a seized clutch arm.
A common problem with these cars.
http://forums.mg-rover.org/showthrea...=1#post3105307
The above link, although a guide to replacing the clutch release arm, will show you where the arm actually is !
You should be able to free it with liberal spraying of penetrating fluid etc.
Good luck.
__________________
His 'n Hers
AndyNickJenkins is offline   Reply With Quote Quick reply to this message
Old 31-07-2012, 20:38   #4
Cpt Shed
Car: MG TF 135
Clutch
I just had an issue with my clutch on my TF, had to replace the slave cylinder, found the clutch arm to be very stiff, so freed it up with oil,all seems good now.
I had the same issue on my ZR, same cure.
Nige'
Cpt Shed is offline   Reply With Quote Quick reply to this message
Old 01-08-2012, 04:05   #5
Tim.
Tim.'s Avatar
Car: MGF Trophy 160, MG ZS180
With a totally pan flat pedal, you will need to loosen the union at the top of the master cylinder to allow air to bleed from there whilst operating the pedal up & down by hand. Once you have some pumping action, re-tighten the union and bleed as normal.
Then you have to sort why it happened in the first place. My money is on a stiff clutch arm and consequently damaged slave seal.
Tim. is offline   Reply With Quote Quick reply to this message
mgf clutch problems / master cylinder? jasper11 Car Care & Detailing Forum 1 02-08-2010 15:55
Price of MGF clutch. Hi all recently did clutch. steve1951 MGF and MGTF (Sponsored by MGFnTFBITZ) 17 22-08-2009 11:04
MGF Clutch problems medcabnath MGF and MGTF (Sponsored by MGFnTFBITZ) 3 12-11-2008 09:20
MGF Clutch problems dalejg MGF and MGTF (Sponsored by MGFnTFBITZ) 3 25-02-2008 17:09
MGF VVC - Clutch Problems adl333 MGF and MGTF (Sponsored by MGFnTFBITZ) 4 02-12-2006 09:10
