Throttle cable adjustment - MG-Rover.org Forums
Old 02-08-2012, 07:46   #1
j70pauzs
Car: mk1 ZS 180
Question Throttle cable adjustment
Hi my 45 diesel has a really slack throttle cable - I have looked around but can't seem to find a How To on adjusting it - Do I just turn the nut?
Sorry to sound like a bit of a numpty.....
Cheers,
Paul
j70pauzs is offline   Reply With Quote Quick reply to this message
Old 02-08-2012, 08:59   #2
Chrisund123
Car: 45 2.0 Diesel
It's dead easy. Pull out the square bit that slots into the bracket. then turn the square bit to tighten or loosen as you see fit.
If you have some basic diagnostic kit (a 10 bluetooth ELM OBD reader and a 3 android app works for me) you can check the throttle position to make sure it's at 99% when the pedal is down, and 0 when it's up.
Chrisund123 is offline   Reply With Quote Quick reply to this message
Old 02-08-2012, 09:12   #3
hougtimo
Car: Rover 800
I've just done this on my 1.8 petrol this morning, and then came here to see this thread!
It's really easy mate. As above, just slide the black clip out with the cable, and twist it to your right to tighten. I warmed the car up, then turned off the engine, took the slack up, and then made sure the idle speed was ok.
Nothing more to it than that. Just be careful of a hot engine!
hougtimo is offline   Reply With Quote Quick reply to this message
Old 02-08-2012, 09:18   #4
j70pauzs
Car: mk1 ZS 180
Talking
Thanks guys, I thought that night be the case but needed clarification!
Paul
Update.....What a difference!!
Well pleased,
Thanks everyone for all your help!!!
Old 02-08-2012, 09:45   #5
hougtimo
Car: Rover 800
Let us know how you get on!
Old 02-08-2012, 12:12   #6
j70pauzs
Car: mk1 ZS 180
Hi, it responds straight away now, I have had the turbo tweaked, just waiting for my new seals for my sdi injectors.....The car is so different now, absolutely stonking!!!
Amazing the difference a slack throttle makes to the car!!!!
Throttle cable adjustment. Flame_TF MGF and MGTF (Sponsored by MGFnTFBITZ) 9 09-04-2011 07:55
throttle cable for 48mm & 52mm throttle body ThumpJunkie For Sale 1 15-02-2010 21:18
Throttle cable adjustment/Broken crank case breather pipe jord79 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 1 08-02-2010 20:28
Throttle cable adjustment Teflon MG ZT / Rover 75 (Sponsored by Rimmer Bros) 9 20-10-2006 19:21
Throttle Cable adjustment Schtopper MG ZS / Rover 45 & 400 14 19-02-2004 19:34
