Rover 218 SD pre 1995 - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Ask The Gurus! - Help and Advice Forums > MG/R Modification & Tuning
Old 19-10-2004, 14:24   #1
ThreeLions66
Car: Rover 200 (-95)
I have a Rover 218 SD pre 1995, can some one tell me if this car has a turbo fitted or am I thinking of a 218 TD?????
ThreeLions66 is offline   Reply With Quote Quick reply to this message
Old 19-10-2004, 14:43   #2
Richard Moss
Guest
Posts: n/a
a turbo should have a "Turbo" badge on the boot.
However, if you open the bonnet and look at the back of the engine (peering over the top of the engine) you will/will not* see a turbo charger attached to the exhaust manifold depending upon whether it is/is not* turbo charged.
* = delete as applicable
Old 19-10-2004, 15:54   #3
cosb6
Car: MG ZR
The unit is a Peugeot unit... in case you are interested. I believe they did both Turbo and normally aspirated ones...
cosb6 is offline   Reply With Quote Quick reply to this message
Old 19-10-2004, 16:16   #4
Richard Moss
Guest
Posts: n/a
Yes, they did both Turbo and naturally aspirated models - the turbo badge was the only visible external difference.
I don't know if the turbo model on the Rover was intercooled and I don't know where that intercooler is mounted - so that won't help any!
Edit: found a 418TD on ebay: the link below shows the engine bay with intercooler (in left hand side of grille aperture) and big, black intercooler hoses (left hand side of engine bay)
http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
Old 19-10-2004, 16:42   #5
Diesel Dick
Car: Other Manufacturer
I there's a dirty great intercooler on top of the engine then it's a turbo. If there isn't, then it's either been pinched or it's NA.
DD.
Diesel Dick is offline   Reply With Quote Quick reply to this message
Old 19-10-2004, 17:51   #6
ThreeLions66
all i have is whats marked in red, can i fit a turbo to it?
Old 19-10-2004, 18:09   #7
Diesel Dick
I can't see! your red marking has hidden most of the detail! If it looks like a small radiator canted on its side and stuck to the top of the engine then you have a turbo my friend.
DD.
Old 19-10-2004, 18:11   #8
Diesel Dick
Sorry. My bad. The intercooler on the Rover is located differently to the same engine in its citroen/pug application. The 2 thick black pipes to the bottom left of the red highlighted area denote an intercooler, and hence a blower.
DD.
Old 19-10-2004, 22:09   #9
Richard Moss
Guest
Posts: n/a
DD.
Is that not what I said earlier? I expect that if there is an intercooler then there is a turbo.
Old 19-10-2004, 23:12   #10
rover 620ti
Car: Rover 75
Send a message via AIM to rover 620ti
It looks just like mine and I have a Turbo one!
rover 620ti is offline   Reply With Quote Quick reply to this message
Old 19-10-2004, 23:12   #11
rover 620ti
Car: Rover 75
the turbo is a 1.7 and the non turbo is a 1.9
Old 20-10-2004, 00:50   #12
Richard Moss
Guest
Posts: n/a
although the engines are visually identical except for the turbo and intercooler.
Old 20-10-2004, 09:37   #13
ThreeLions66
ok i have the arrowed items, but the part on top of the engine is a bit smaller than that shown, if i haven't can i get one fitted??
Old 20-10-2004, 10:26   #14
Diesel Dick
Sorry Mossy, you're right. i'm just getting my applications in a twist (and going mad).
DD.
Old 20-10-2004, 11:32   #15
Richard Moss
Guest
Posts: n/a
If you weren't mad, DD, they'd have to chuck you out of the Police.
Quote from Spike Milligan in his war memoirs:
On stopping for a break whilst driving his CO through the desert, the offcier asked Milligan why he wasn't getting out of the staff car to "stretch his legs".
Milligan: My legs are long enough already, Sir!
Officer: Milligan, if you go on like that we'll have you kicked out of the Army on grounds of insanity.
Milligan: But sir, isn't that how you get in to start with?
rover 218 SD Turbo '96 alican Diesel Forum! 1 06-11-2008 20:41
1995 218 SD 5dr help..... GerbilPower 'R8' Rovers (aka Wedges!!) 2 04-06-2007 12:41
Rover 218 sd For Sale tebster For Sale 13 02-07-2005 18:57
Rover 100 1.5 Sd 1995 ANDYSUDS Metro / Rover 100 2 01-12-2004 21:17
Rover 218 SD Scoobymyk For Sale 7 01-12-2004 14:32
