No Hot Air.... - Forums
Go Back Forums > Model Specific Forums > MG ZS / Rover 45 & 400
Old 20-03-2013, 11:54   #1
Car: Rover 45
No Hot Air....
Was driving along yesterday and switched on the air con to find it only blowing cold air. The engine temp began to rise and was about a cm below the red just as I ended my journey. Topped up immediately with coolant/water and the temp sits about a quarter not long after startin the engine but never rises above that, however, I am finding that there is still little in the way of any warmth in the air blown. Always had an issue with having to top up the reservior though, but not this cold air issue. Took the cap off the engine and there's nothing in the way of nasty colours there.... Help please!
Rickosa is offline   Reply With Quote Quick reply to this message
Old 20-03-2013, 17:04   #2
Discount MG Rover Spares (Formerly Mattyprice4004)
DMGRS's Avatar
Car: MG ZT-T+ CDTi Auto
Send a message via MSN to DMGRS
Sounds like you need to fix your water leak, as it'll keep airlocking until you do.
DMGRS is offline   Reply With Quote Quick reply to this message
Old 20-03-2013, 18:03   #3
Car: MG ZS+ / Insignia SRi
As above - find and repair the cause of the water leak before it causes the Head Gasket to fail. I would suggest this is something you would want to do quite urgently...
mr_wigster is offline   Reply With Quote Quick reply to this message
Old 20-03-2013, 18:07   #4
MG-Rover Mobile Mechanics
**Kayleigh**'s Avatar
Car: MGF x6, MGTF x4, MGZS x4, MGZR x5, MGZT x2, 93' CELICA, Recovery Truck x2
Send a message via MSN to **Kayleigh**
I agree with both of the above comments. Very sound advice x
**Kayleigh** is offline   Reply With Quote Quick reply to this message
In order to be able to post messages on the Forums forums, you must first register.
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Date of Birth
Month Day Year
Air Con Blowing Hot Air!!!!! azreal MG ZR / Rover 25, 200 & Streetwise 4 10-06-2008 03:37
No hot air only air con or cold but engines pipes are hot????? EMMA1980 MG ZR / Rover 25, 200 & Streetwise 5 28-01-2008 18:10
Air blowers not giving out hot air. impulse1985m Others 16 06-05-2006 16:51
direct air filter,induction kit,hot air problem DoUbLe cLuTcH MG/R Modification & Tuning 0 04-12-2002 15:23
