Anyone got a spare working injector? - MG-Rover.org Forums
Old 06-08-2014, 15:57   #1
simcor
Tournaments Won: 1
Car: MKII MG ZT-T+ CDTI 135 (PEARL BLACK, MANUAL) 140K and counting!!
Just an off chance if anyone has a working injector kicking around for a diesel. Thinking of trying swapping injectors out to see if it an injector issue on my ZTT. Don't really want to buy one at the moment due to cost, I also don't want to take them all out and send then off to be checked at the moment as the car is currently off road sorned but I will need to move it around the car park so want it still running. I can cover postage if anyone has one they don't need and or send it back once I have had chance to swap them out one by one. Worth a try maybe. I have not given up completely yet on it, might hang on to it if I can get it all sorted as a second car maybe.
simcor is online now   Reply With Quote Quick reply to this message
Old 08-08-2014, 18:21   #2
simcor
Tournaments Won: 1
I've bought a second hand one off eBay for just 12 quid so worth a try at that price, if it's goosed I'll be able to get my money back anyway. Might help confirm if I have injector issues or not.
Old 08-08-2014, 23:21   #3
zony
Car: MG ZT-T CDTi+ 135/ Mini Cooper 1998 Classic
I'm glad your not losing complete faith in it. Just replaced the clutch master cylinder on mine with a Tazu one, but pedal is going weird again, so its def the slave goosed. Its only been in two years. Been a depressing few days.
zony is offline   Reply With Quote Quick reply to this message
Old 09-08-2014, 08:11   #4
simcor
Tournaments Won: 1
Both of my replacement slaves didn't last that long a matter of months for me.
Old 09-08-2014, 08:44   #5
FrenchMike
Car: Rover 75 CDT
Hi Mates,
Just happened on me today .only 20.000km
Slave from ECP2004 ,5 years ago !
Mike
FrenchMike is offline   Reply With Quote Quick reply to this message
Old 09-08-2014, 20:28   #6
zony
So are the LUK ones the best?
Old 09-08-2014, 21:20   #7
simcor
Tournaments Won: 1
I think both of mine were LUK parts.
Old 09-08-2014, 21:38   #8
FrenchMike
Car: Rover 75 CDT
Hi Simon,
Do you remenber it was 5 years ago !
Have you done a analysis ? what was wrong with them ? was the seals damaged ?
Now yet dismantled mine but i have found on the top ,lot of play around the pipe .
(the metal one is smaller than the genuine plastic one) .
And i guess with the engine vibrations , lot of stresses are sent to the
connection slave side . may be producing some micro air ingress ?
I have no loss of fluid but pedal to floor.
What do you think about it ?
Tomorrow,i 'll know more ...
Mike
Old 10-08-2014, 15:29   #9
simcor
Tournaments Won: 1
No idea Mike, was it really 5 years ago?
The first slave had come apart in transit and I foolishly put it back together and fitted it. The second one seemed OK and was fitted but soon had pedal trouble.
Old 11-08-2014, 12:18   #10
wullie480
Car: 2 x MG ZT CDTI+ 135
Hi Bud,
I thought I'd get the other one as a spare but the sellers upped the price to £30.
How did it go did you get a chance to swap them over.
wullie480 is offline   Reply With Quote Quick reply to this message
Old 11-08-2014, 14:04   #11
simcor
Tournaments Won: 1
Not yet dude, royal mail tried to deliver it today but I was at work gonna take a day or two to go and pick it up. Have to leave it 24hrs before going to collect it sadly.
Old 11-08-2014, 17:54   #12
FrenchMike
Car: Rover 75 CDT
Simon,
Just dismantled the clutch slave ... no apparent leak of fluid ...
Tested Under 2 bars of air ....no bubles !
That leaves me perplex .....
Mike
Old 13-08-2014, 13:55   #13
simcor
Tournaments Won: 1
Indeed perplexing Mike. I wonder is your fluid black and has contamination in it? I'm wondering if as you say its not a fluid leak but detritus blocking the pipe passageways or as you say air entering somewhere and an airlock.
Old 14-08-2014, 07:58   #14
simcor
Tournaments Won: 1
Still need to go and collect my parcel from royal fail, so still no closer to trying it out. Mind you probably wouldnt have had time this week anyway.
Old 14-08-2014, 09:08   #15
FrenchMike
Car: Rover 75 CDT
No contamination ,everything seems good including the seal:
in doubt B&B and Tazu ordered ...
Mike
Old 15-08-2014, 15:11   #16
FrenchMike
Car: Rover 75 CDT
Smile Last news
Today master leak test and guess what ::::Big bubbles
So ,quick fit disconnected and hard pedal means NOTHING .
Then,i have dismantled the beast ...very simple and easy :
You have a grey seal looking correct ? and another small one Under a
little spring playing as a valve .
Observing with à magnifier a have found something very interesting
Next,decided to clean it simply and..
Then ,reassemby and testing again and....
I dare say ,i'm fairly satisfied having found the reason WHY
All comments are welcome
Mike
Old 15-08-2014, 18:18   #17
simcor
Tournaments Won: 1
Interesting Mike, I might whip my master off and check it over at some point although if I do have a leak I suspect it will be the slave again maybe in my case. Injector picked up from sorting office today so might see about trying that tomorrow depending on the weather.
Old 15-08-2014, 19:34   #18
FrenchMike
Car: Rover 75 CDT
Not sure,the débris stick more easily on a flat seal (master) .
In the slave,there is less risk ;they are blade shaped
like on brakes .
The problem is to find how to clean it in situ !!!!!
Old 15-08-2014, 20:57   #19
Mike Noc
Car: Rover 75 CDT Con. SE. Bike: Norton Commando Roadster 750 Mk V
Maybe regular changing of the fluid Mike, so that the debris is flushed out before it has a chance to build up?
Mike Noc is online now   Reply With Quote Quick reply to this message
Old 15-08-2014, 21:29   #20
FrenchMike
Car: Rover 75 CDT
i think so too ,but to be efficient,the valve must be open while flushing..
this infamous seal.
don't see how to...
Or fit a Tazu which seems different:
Mike
Spare key fob not working : JIMS2851 MGF and MGTF (Sponsored by MGFnTFBITZ) 7 10-02-2013 13:08
injector going spare? Phil_D's45 Diesel Forum! 2 01-05-2012 21:37
Injector pump and number 1 injector leaking markzt4811 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 0 18-02-2011 20:50
a spare spare wheel pwatts1977 MGF and MGTF (Sponsored by MGFnTFBITZ) 28 23-05-2010 22:47
spare time and spare paint = nickc09 MG ZR / Rover 25, 200 & Streetwise 3 30-09-2009 00:09
