Rover 45 starting problem - MG-Rover.org Forums
Old 08-08-2005, 23:55   #1
ally2462001
Car: Rover 45
can anyone help, car turns over but doesn't fire. occasionally starts first time, but normally takes 10 turns of key or more. when started, goes like a dream. have had new starting motor, new fuel pump, new immobiliser and it still wont start. its driving me mad!!! any advice welcome
ally2462001 is offline   Reply With Quote Quick reply to this message
Old 09-08-2005, 21:41   #2
mg_xpower
Car: MGF
Send a message via MSN to mg_xpower
Do the sparkplugs fire when it isn't starting ? Do you smell petrol ? Do you hear the fuelpump starting when you put the ignition to II (before starting)
You'll need to know this in order to find the problem. Changing the immobilizer startermotor and fuelpump doesn't make sense to me since they can all be simply tested ?
mg_xpower is offline   Reply With Quote Quick reply to this message
Old 10-08-2005, 00:19   #3
Vincero
Car: Vauxhall 'Serious Business' Omega
You have checked the HT leads and all the connections going to the coil pack??? Distributor also if you have one.
Vincero is offline   Reply With Quote Quick reply to this message
Old 10-08-2005, 10:19   #4
ally2462001
Car: Rover 45
have found out since even crank sensor been done, all leads etc have been checked as garage been doing it all, but even they are stumped! the garages latest idea is the alarm system got a fault in it!
to mg_xpower, yes to spark no to petrol smell, yes to fuel pump
Old 10-08-2005, 12:17   #5
Ron
Car: Seat Leon
Send a message via Yahoo to Ron
Starting Problems
Might be obvious but have youn tried substituing the battery with a new one/fully charged/reliable one ?
Ron
Ron is offline   Reply With Quote Quick reply to this message
Old 10-08-2005, 13:03   #6
Rover_ron
Car: Other Manufacturer
Once it has started, if you stop it soon after, does it start up again straight away?
So is the problem there only when the engine is stone cold or does it happen at random?
In other words, I'm thinking it my be the cold start enrichment. After 10 attempts enough fuel may have been injected for it to start.
Forgot to mention checking the battery cables - esp the neg lead at body earth point. I remember an earlier thread where this can cause poor starting due to the ecu not getting a good earth. I'd undo all the battery connections at both ends and clean them up. (make sure you have the radio code)
Rover_ron is offline   Reply With Quote Quick reply to this message
Old 10-08-2005, 17:06   #7
cjmillsnun
Car: MGF Trophy 160 in Trophy Yellow
Send a message via MSN to cjmillsnun
Yes I am leaning towards this. I suspect it may be either a faulty Coolant temerature sensor (most likely) which is reading warm all the time,
a faulty/sticking IACV.
cjmillsnun is offline   Reply With Quote Quick reply to this message
Old 10-08-2005, 17:22   #8
ally2462001
Car: Rover 45
Unhappy
she runs perfectly and starts up ok after being turned off, its just the initial start up when i need to use her. would like to thank everyone for their advice to this problem, am passing it all on to garage as they haven't got a clue, nor has local rover garage!
Old 10-08-2005, 18:17   #9
wol6
Car: honda crv
check the cranking voltage may be the battery should not drop below 9volts
wol6 is offline   Reply With Quote Quick reply to this message
Old 10-08-2005, 19:43   #10
dazultra2000
Car: ZS120+ Hatch
Send a message via ICQ to dazultra2000 Send a message via AIM to dazultra2000 Send a message via MSN to dazultra2000 Send a message via Yahoo to dazultra2000
OK ignore the post - didn't see you'd done the crank sensor.
dazultra2000 is offline   Reply With Quote Quick reply to this message
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Rover 45 starting problem?? nathplummer MG ZS / Rover 45 & 400 4 25-10-2008 18:52
rover 45 starting problem swatrfc MG ZS / Rover 45 & 400 0 28-04-2008 20:06
rover 45 starting problem paulineb MG ZS / Rover 45 & 400 10 15-06-2007 16:03
Rover 45 Starting Problem _Paul_ MG ZS / Rover 45 & 400 7 22-12-2006 16:17
Rover 45 1.4: Starting problem nightbird MG ZS / Rover 45 & 400 6 09-02-2003 07:59
