How do I manually reset the engine check light on Rover 25? - MG-Rover.org Forums
Old 09-08-2005, 11:21   #1
taylv001
Car: Rover 25
Smile How do I manually reset the engine check light on Rover 25?
Please can somebody help with this simple question,
thanks
taylv001 is offline   Reply With Quote
Old 09-08-2005, 13:09   #2
Rover_ron
Car: Other Manufacturer
thanks
Is it a petrol or diesel?
If its petrol, you can use a DIY code reader (laptop also needed) which plugs into the diagnostic socket in the drivers foot well. (£70-90)
Or you can take it to a auto/fuel injection/independent garage or a main dealer. The independents will charge about £20-30, the main dealer about double. Try your yellow pages.
If it is a diesel pre 2004/5 you CANNOT reset the light with any diy diag tools/code readers. (because the ECU requires security access)
Rover_ron is offline   Reply With Quote
Old 09-08-2005, 14:01   #3
taylv001
Car: Rover 25
Thanks for that, it's petrol and therefore looks like I'll have to fork out for it, didn't know if there was a procedure for doing so without all the gadgets, (similar to resetting the stepper motor on previous models or something)
Ta
Old 09-08-2005, 17:35   #4
Rover_ron
Ta
No those days are long gone.
Do you know why the MIL came on in the first place?
The garage will be able to tell you which code (or codes) have been logged which will give you a clue.
Old 09-08-2005, 21:24   #5
wol6
Car: honda crv
mil lamp
if the lamps on then there is a fault
fix the fault then the lamp will go out
do you live in the west midlands???
contact me for more info i you wish
many thanks
wol
wol6 is offline   Reply With Quote
Old 11-08-2005, 09:09   #6
taylv001
Car: Rover 25
Scenario is:
Lamp came on
Rover dealer diagnosed and said "new MAP sensor needed"
Fitted sensor myself
lamp still on.
Any suggestions?
Old 11-08-2005, 11:24   #7
cosb6
Car: MG ZR
It wasn't the MAP sensor that was faulty... would be my suggestion....
cosb6 is offline   Reply With Quote
Old 11-08-2005, 11:34   #8
Dave turbo
Scenario is:
Lamp came on
lamp still on.
Any suggestions?
It usually take about 4 days driving to reset.
I had a decat and after 4 days the check light came on, fitted a MIL eliminator (fools the sensor into thinking there is a cat there) and after 4 days again it went out. Not sure if its the amount of times the car is started or days or miles, but definately on mine it seems like 4 days to adjust.
Or you can have it reset by the diagnostic machine.
Dave turbo is offline   Reply With Quote
Old 12-08-2005, 06:41   #9
Rover_ron
On the diesels, the MIL will not go out even when the fault is fixed. The throttle position sensor went on my 45TDi, causing limp home mode. (Revs fixed at 1300)
I replaced the sensor, car drove normally, but the MIL remained on for 6 weeks until I had it reset by a independent with an ACR4.
The pre '99 cars would normally only light the MIl whilst the fault was present. Switching the ignition off and on again resets it. These cars are not EOBD compliant.
I believe the later cars are like the L series diesel so the light will never go off of its own accord.
Indeed, the EOBD standard requires it to be manually reset.
You may not post replies
rover 25 engine check light morPHumax3985 MG ZR / Rover 25, 200 & Streetwise 1 27-10-2008 19:03
Rover 25 SRS airbag light reset pantsman28 MG ZR / Rover 25, 200 & Streetwise 9 21-03-2008 18:47
rover 416sli check engine light mick100 MG ZS / Rover 45 & 400 4 30-08-2007 21:53
Check Engine Light On Again !!IS there no way to Diy Reset the Ecu ?? DeanF MG ZR / Rover 25, 200 & Streetwise 4 06-02-2007 11:32
"Check Engine" light on after service interval reset Tony1 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 10 11-08-2006 00:10
