Thread Tools |
Rating:
Display Modes |
#1 |
Car: Rover 400 (95-99)
One good thing is that it still works , which is nice.
The problem is that it won't stop when you try and close it. Example: Sunroof open in the slide mode, push the button to close and it will continue to open in tilt mode. It won't stop unless you pull your finger off the button in time! Is there a microswitch I can replace/clean that registers the sunroof closed? Many thanks! |
| Sponsored Links | |||
Advertisement | |||
#2 |
Car: Other Manufacturer
I'm not sure but I think there may be a microswitch in the motor. Paul
#3 |
Is the motor easy to get at? Or should I just put up with it?
TIA! |
#4 |
Anybody?
It's doing my nut in.
#5 |
Car: Silver Stormer ZR turbo.
The motor is easily accessable if take the headlining off. You can see it if you pull the sunroof trim off on the headlining and then pull the headlining down a bit.
#7 | |
Administrator
__________________
#8 | |
?Major, how could you? |
| Bookmarks |
| Thread Tools | |
| 97 414 not starting-please help quick!! | jmiles | MG ZS / Rover 45 & 400 | 3 | 20-06-2007 19:47 |
| '97 414 gearbox noise | Torq | MG ZS / Rover 45 & 400 | 9 | 23-03-2006 09:32 |
| Sunroof Botchup Rover 216Sli '97 | Pixie_0 | MG ZR / Rover 25, 200 & Streetwise | 10 | 23-11-2004 21:53 |
| i have a '97 414 Si ...... | timmy toad | MG ZS / Rover 45 & 400 | 7 | 21-11-2003 16:40 |
| '97 414 Alternator | mikew7790 | MG ZS / Rover 45 & 400 | 3 | 19-12-2002 18:19 |
