Tail Lights - MG-Rover.org Forums
Old 05-09-2005, 08:34   #1
CJZR105+
Car: MG ZR
Tail Lights
Guys,
Anyone know the part number and wattage of the rear tail lights for the ZR? I think they are 10w but need to be sure.
Got an intermitant problem. Sometimes when i turn the lights on, the rear nearside fails to light. Other times it's fine. Bulb looks to be ok, and all circuit is fine, dry and clean.
Put a new bulb in (but not the right one for the job) just to see if it was the socket, and it worked fine.
Put the old one back in and nothing! What is odd though, if i leave the lights on for a while, it will come on after a few minutes.
I think it's a dodgy bulb.
Any idea's? I need a part number for them too if anyone know's of it?
CJZR105+ is offline   Reply With Quote
Old 05-09-2005, 08:55   #2
cjmillsnun
Car: MGF Trophy 160 in Trophy Yellow
Send a message via MSN to cjmillsnun
Sounds like the bulb is dodgy, probably worth replacing it.
Easiest way is to take the old bulb out of the cluster, go to local car accessory shop and find one the same.
Halfords will actally list which bulb is the right one for your car with their little card thingys by the bulbs.
cjmillsnun is offline   Reply With Quote
Old 05-09-2005, 09:23   #3
ashy
Car: Silver Stormer ZR turbo.
You don't need a part number just take it to wherever you're getting the bulb from and match it up. They usually have a list of compatible types anyway.
The rating should be on the bulb.
The bulb should be a 245/12v/10w
ashy is offline   Reply With Quote
Old 05-09-2005, 09:51   #4
no1knows
Car: MG ZS+ Gun metal grey !!
Send a message via MSN to no1knows Send a message via Yahoo to no1knows
hey had that problem with my old 200 , check out the connector to the cluster, one of my strips of metal was slightly bent & so occastionally came away from the rest, it was always dodgy sometimes it didn't work then a comedy HIT to it ( as your hit a tv or monitor *thud* ) & it worked again, lol until I could be arsed to look at it.....
perhaps its your problem too ??
no1knows is offline   Reply With Quote
Old 05-09-2005, 10:14   #5
CJZR105+
Car: MG ZR
I did have a brief look at that electrical connection last night, but light was poor so couldn't really see much.
You could well be right. I'll have another look either later if i get the time, or tomorrow.
Thanks for the bulb info too. I must admit i was leaning towards it being a faulty bulb, and so replacing them would cure it.
Non of the metal strips are bent, i'm sure of that, but the actual wire in the connector that clips to the tail light bulb, may not be pushed home properly.
Thanks for all you advice and help, very much appreciate it.
I'll have a look later.
Old 26-10-2005, 12:32   #6
mtimweb
Access to rear bulb
How do I remove the cluster to replace a rear bulb?
mtimweb is offline   Reply With Quote
Old 26-10-2005, 14:16   #7
empsburna
Car: Other Manufacturer
pull the carpet back on the boot and its straightforward from then on in
empsburna is offline   Reply With Quote
You may not post replies
Tail Lights SMC_ROVER_25 MG ZR / Rover 25, 200 & Streetwise 0 29-03-2008 23:02
tail lights SMC_ROVER_25 MG ZR / Rover 25, 200 & Streetwise 31 03-03-2008 13:19
Which Tail Lights Are Best?? michaelb MG ZS / Rover 45 & 400 9 29-07-2007 20:54
Tail lights doublekite MG ZT / Rover 75 (Sponsored by Rimmer Bros) 7 02-07-2007 17:58
Tail lights mezr Others 2 13-05-2004 18:57
