#1 |
Car: Other Manufacturer
Hi Guys sorry to crash your site but off to look at my mates 400 ,He has lost the turbo he says?
More than likely it will be in Limp mode i think or one the hoses has gone maybe Any advice would be greatful i.e sensors,maf,ecu related to sorting problem Cheers ..........Steve |
| Sponsored Links | |||
Advertisement | |||
#2 |
Location: Leeds Car: MG ZT 135+ (Plus Pack) Suzuki SV650
It'll be the maf, 95% certain
#3 |
Thats what i thought is there anyway i can sort it without replacing i.e stripping down and cleaning sensor tip?
If i was to replace were is the best place to get it from? And is there web pages on here with tech data as fitment diagrams Cheers .Steve |
#4 |
sorry made a typo there the model is 620 not 400 doohh!!!
#5 |
MGR East Anglia rep
I assume it is a diesel rather than a petrol turbo, but then again if it is a 620, it could well be either.
Lets assume it is a diesel, take a look at the following site, it belongs to Rover Ron who is a diesel god on this site. http://www.45zs.info/ Cheers 25tdi |
#6 |
620ti is the Model (Petrol)
More info regarding the problem after seeing the car Hunting alittle 7500rpm tick over No Turbo at all and only revs to 4500rpm when under load and no power at 4500rpm Cheers |
#7 |
Anybody Know?
#8 |
Guest
Posts: n/a
Carefully check all the million and one vacuum pipes running to/from the turbo, ECU and manifold.
#9 |
Have checked all hoses they seem fine,and if they were leaking a little you would still get boost? and there is nothing
#10 |
crank sensor loose?? my nasp did this.
#11 |
were is that situated ?
#12 |
Just behind the engine close to the gearbox. just double check its tight and the wires connected.
#13 |
***********************Removed******************** *******
#14 | |
If the actuator diaphram was perforated, it would run massive boost and hit the boost cut. So neither of your suggestions would lead to running no boost. Steve |
#15 |
Ok fair enough.
#16 |
Location: Gloucestershire - Cotswold Cockney Car: MG Montego Turbo; Rover 25; R620ti x2 & MGZS 120+ x2
From your description, again check the turbo and particularly intercooler hoses for security. Whilst driving, a loose hose may come off allowing boost to escape giving the effects exactly as you describe. Then when you check them with car stopped they have closed up looking normal again.
When this happened to my Ti one time, all looked well. However, that main hose connected to the throttle assembly was a little loose and this allowed boost pressure to escape.
__________________
. So, now you wanna buy a BMW .... Huh! No natural class ... ![]() Normally aspirated engines suck. They really do. Good job turbocharged engines blow and suck. That's better. |
| Bookmarks |
| Thread Tools | |
| 400 turbo convertion??? | Kev 94 vitty | MG ZS / Rover 45 & 400 | 0 | 13-02-2007 23:02 |
| Rover 400 SDi Turbo Air Con Problem | JohnnyLarge | MG ZS / Rover 45 & 400 | 2 | 26-07-2006 20:28 |
| Mates mk3 200 bubble problem | shadybarry218iS | MG ZR / Rover 25, 200 & Streetwise | 6 | 26-04-2006 01:53 |
| 2.0 turbo into a mk2 400? | SDI200 | MG/R Modification & Tuning | 15 | 11-12-2005 18:57 |
| Rover 400 Turbo Problem | Fudgie 73 | 'R8' Rovers (aka Wedges!!) | 4 | 12-11-2004 09:51 |
