MG ZS 180 Master cylinder - MG-Rover.org Forums
post #1 of 9 (permalink) Old 05-01-2016, 09:42 Thread Starter
Hi, I am in desperate need of a master cylinder for an MG ZS 180, MUST BE IN GOOD WORKING ORDER please
Many Thanks
nicko500s is offline
post #2 of 9 (permalink) Old 05-01-2016, 10:55
try a freelander unit
Hi, I've used a freelander master and swapped over the clevice. There are some good instructions on how to do this on the web.
stjs16 is offline
post #3 of 9 (permalink) Old 05-01-2016, 13:11 Thread Starter
Thanks, l will look into that but really need a new or used original as the garage don't want to mess about too much.
I have the part number for the original part as SJJ 100 390 is anyone able to confirm this please?
post #4 of 9 (permalink) Old 05-01-2016, 16:17
minesarover is offline
post #5 of 9 (permalink) Old 07-01-2016, 11:09 Thread Starter
Thanks, I checked with rimmers and they are NLA.
I ordered one off ebay which had a different P/N so I am hoping it will work.
post #6 of 9 (permalink) Old 08-01-2016, 06:53
Car: MG3 Style, previously ZS180 Saloon in XPG
The only part listed in the parts catalogue for the 180 is the afore-mentioned SJJ100390.
stefan161 is offline
post #7 of 9 (permalink) Old 09-01-2016, 12:02 Thread Starter
Thanks Stefan. Despite checking with the supplier on ebay before purchase the bmc was wrong and has been returned.
From what the garage say these are no longer available in that no one has stock of any that they could find, luckily I found one in the workshop and just incase I bought another off a fb group so one of those should be good.
In case this is of use to anyone the MG ZS 180 BMC visually differs to the std bmc in that the std bmc has the forward most break pipe mounted vertically whereas the 180 bmc has this offset, towards the offside of the car.
post #8 of 9 (permalink) Old 09-01-2016, 12:54
RING Lakeland Mini - they were the only place who could supply the correct master cylinder for my wifes ZR160 a couple of years ago.
post #9 of 9 (permalink) Old 20-02-2017, 14:35
Nick
Can you confirm if the 1.8 and 2.5 brake masters are different lengths?
Soneji is offline
slave cylinder or master cylinder tom9911 England - South West 0 20-06-2010 08:42
MG ZS 180 Master Cylinder Coupling Removal twoboys MG ZS / Rover 45 & 400 15 24-04-2010 19:58
clutch-slave cylinder,master cylinder cost kumala MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 28-01-2010 16:48
Help! - ZS180 Slave cylinder/Master Cylinder Junior24 MG ZS / Rover 45 & 400 7 26-07-2008 22:27
seperate the master cylinder from the slave cylinder mcnmihail MG ZS / Rover 45 & 400 1 06-10-2007 20:10
