I have a chip for a D16 DOHC engine setup running 185bhp with prelude 345cc injectors. PP4-R00 or G01 are the ones you want.
Suprised Ian didnt point you my direction for the chip/map.
Hi Jonny,
sorry for digging up an old posting but heres hoping....
So Ive just started on a new project 216 D16z6, SOHC rover coupe.
So Im adding turbo probably t25, following only rebuilds for boost, and putting in the skunk2 manifold, and forged low compression pistons which will help me for higher boost.
Onto how to get it running.
Is there any way you could assist me with finding a base map or ECU that I could plugin... Now I have MPPS / AlienTek KESS and other mapping hardware available to me, along with some direct to chip mappers. Looks like I should socket an ECU to allow this first.
Any help with this is greatly appreciated - so if you either have a socket ECU there, or a base map that accepts boost which I could then take and adjust for my injector type / boost level etc, I would be extremely happy.
Otherwise I will have to buy a wideband AFR and start doing some data logging runs and just tune it all up myself from scratch which will take some time..
Thanks in advance.. Trev.
