1 - 2 of 2 Posts
rover_600
Hello,
i need new gearbox for my 620ti, but i cant find any (car scrapyards in Czech Rep. or ebay). Can you please tell me if there is some compatible gearbox from 600 with different engines or from different rover/mg/landrover models which would straight fit in my 620ti ?
Or is it possible to fit internals from another PG1 gearbox to 620ti pg1 housing?
I dont care about difference in gear ratios or absence torsen diff, I am trying to keep the car alive.
Mára
Hi Màra
The only other 600 model fitted with a PG1 box is the diesel.
But I think that PG1 boxes from any MG Rover FWD car with M-, O- or T-series engines will fit.
That is Maestro/Montegos with 2.0 engines, Rover 220, 420 and 820. Gear ratios will not match and speedometer will probably not show correct speed. Also note that the gearboxes used in the turbo engined cars have uprated bearings to handle the higher torque.
Because of the difference in bearings, I’m not certain which internals are interchangeable.
I hope you will find a suitabale gerbox to get your ti running.
Per E.
1 - 2 of 2 Posts
