Has anyone an idea how to de-assemble the indicator compartment of an Rover25, if found 4 srews, 2 of them are visable (upper side op the dash) and the other 2 are hidden behind a rubber that is easly removed. But when these 4 screws are loose, i stil can't remove the cover... it seems to be stuck somewhere... but i don't want to break something. Can i do something wrong when i de-assemble something? is it better to disconnect the battery? Tnx, Kevin.
Sorry... what i ment is the compartment where the speed and gas and rpm meter is in... becouse in there is an anoying rattle :~( and i want it to get out
tnx, kevin
Nothing broken, and a lot of the rattle and creaking is fixed, just by stuffing up the open spaces in the dash with islolation material (foam). In the left corner, almost near the front-windshield is still a creaking noise, but i can't seem to get that out... i can't get near it enough (hurted my fingers on trying)
Another thing is the shelf in the boot of the car (the thing where you can leave you umbrella on and seperates the boot from the interior, i don't know how it is named in english) every bump you take it hops up, and i find that anoying, any suggestion for fixing that? Of course without loosing acces to the luggage boot.
euhm... what are hinges (plastic)? think i'm not understanding completly... can you add a little more detail an maybe a partnumber of that thing, and how do you fit that (those)?
tnx dave
Tnx Dave, i phoned my local dealer, but he didn't know the part, neither the part number (it didn't show up in his computer), they would phone the head-dealer in brussels to ask about it... fingers crossed
Again, tnx allot for you help !!!
The parcel shelf has a metal bar running through it, underneath.
The plastic 'hinges' fix into this hollow bar, by an interference fit8)
Basically, bash the new ones in, while first making sure you get them in the right way up>=(coz if you get it wrong, you can only use them once:red:
Sometimes, a little super-glue helps
Related Threads
MG-Rover.org Forums
5.9M posts
138.9K members
Since 2001
