1 - 20 of 67 Posts
I think its about time there was a sticky/thread that gave info about what other model car bits, fit an MGF/TF:england:
..................it could save folks a lot of money,.....I found mentioning MGF/TF, and the price goes up, and up...
ORANGE address need to be copied and pasted at present....
DONOR CAR MODS.
ITEM.....................................CAR MODEL.....................POST No
Alloy 17" ZR Wheels.....................MGF/?..........R ZR..http://forums.mg-rover.org/showthread.php?t=292529&highlight=zr+wheels#20,21,22,23
Chrome Rings for Pod/Dash............MGTF/?.........200/400+http://forums.mg-rover.org/showthread.php?t=287954&highlight=rover+200
Front Fogs.................................MGTF.............25/45/ZR/ZS/ZT Part No.XBJ105510 + XBJ 105500
Front Splitter..............................MGT/TF.........SEAT LEON http://forums.mg-rover.org/showthread.php?t=244042&highlight=seat+front+splitter
Heater air vent switches/controls from a 2000 onwards peugeot 406 fit F/TF's #44
Intermittent Wipers......................MGF/TF........R800..http://forums.mg-rover.org/showthread.php?t=143946
Middle Air Vent Unit......................MGF/...........R200 http://forums.mg-rover.org/showthread.php?t=323674&highlight=middle+air+vent
Multi Functional Unit.....................MGF/TF........R200+..................#5
Rear Track End control arm............MGF/ ........ R200 late..............#27 ,#29
Side Window Motor Lift................. MGF............R400.............#2
Sub Frames.................................MGF/TF........Metro............#10 http://forums.mg-rover.org/showthread.php?t=326126
Washer Jets................................MGF/TF...........Citreon/Peugeot #40 http://forums.mg-rover.org/showthread.php?t=237802&highlight=Citroen+washer+jets
?? ANYONE HELP......Late ROVER Mini (not BMW style imitation) Steering wheel.
??ANYONE HELP.......Metro/Rover 100 wing mirrors - manual only I think though.
??ANYONE HELP........Throttle bodies from 'most' K series engines.
MODS, THAT COULD BE DONOR......
Different exhaust...........to suit MGF/TF....................http://forums.mg-rover.org/showthread.php?t=323720
Low Fuel Warning Light...............200/25/ZR/MGF and MGTF..........http://forums.mg-rover.org/showthread.php?t=295193&highlight=low+fuel+light
Low Level Coolant Sensor Modification..........MGF/TF...all?............ #46
CHEAP FIXES
Heater Resistors http://forums.mg-rover.org/showthread.php?t=218770
ONE TO WATCH............................................
TF Compatable Spoilers...........http://forums.mg-rover.org/showthread.php?p=3430493#post3430493
Update...15.11.09...................http://forums.mg-rover.org/showthread.php?t=328753
Please keep your donor mods coming, if I have interpreted wrongly, please let me know...
The simpler the better I say. # stands for post number, people can give as much info as possible and any links
to various articles on their posting, how too's, part no's etc
If when you post, and later want to say/add/takeout something, if folks edit their original page, it'll keep things altogether...
Discussion Starter #2
EG:
Originally Posted by legend_of_chaos
I think my motor has gone for my drivers side window, when i lift it up it stops half way and the motor makes an awful sound, same coming down, where is the best place to buy a new one from, don't want secondhand as it may go again and the money spent could buy a new one i imagine.
I replaced one for somebodys F, cost £4 from a rover 400 and its still going strong 4 years later! if you didnt know the TF units are poorly made and the units in the MGF's are better quality so you could of fitted a used one of them also_Originally Posted by Craigie TF
Great idea Mindy. If the list starts getting long are you going to rearrange in alphabetical order or engine body electrics etc. Rather than everyone having to read every post, in hope. and are you going for direct fits or can be fitted with a bit of modification. Rep for idea. Hope it takes off.
Steve
Discussion Starter #4
Steve
Lets split into appropiate groups and alphabetical order ( given time) not sure how too, but mods might help.It won't work without input, even if folks mention a mod seen, all mods ok, if classed as EASY...
MEDIUM,.....LITTLE HARDER,......FOR THE NOT TO SHY....etc
thanks for rep.... A,...NOT FOR THE FAINT HEARTED......B....etc
Discussion Starter #5 (Edited)
MFU...Multi Functional Unit...........MGTF
ISSUE: internal lights won't go out,.......other possibilities,....but......
Red box clipped on behind internal fuse board (drivers side knee)
http://forums.mg-rover.org/showthread.php?t=318107
ISSUE....
The same unit was used on the 200, 400, 25, 45, ZR, ZS, F and TF so it should be easy to find one at a scrapyard etc.
Interior items only? Only reason why i say this is that the engine can be any K series so most engine parts should swop over.
Technozens Low Fuel light.....
Glove box..... lol
Stearing wheel..
Indicators.... R400
..............................................................it could save folks a lot of money,.....I found mentioning MGT/TF, and the price goes up, and up...
:england:
Good idea.
Compare part numbers on the EPC?
Ask an XPART Parts Stockist?
Speak with Rimmer Bros?
Start a thread yourself and maintain post#1?
Start a site like petevick did?
mg_zt
Great idea, I used to run yank motors for many years and with a bit of work found that things like an oil filter from a john deer tractor was the same as a ford 5.7 v8 but was less than half the price. As someone new to MGs it would be great to know of cheeper alternatives.
Discussion Starter #11
Thanks, for the ideas,I shall look into more at the weekend, more time then.
I think the original parts/donor needs to be created in a way as simple as poss. like a Book, Chapter, Page. ( B=Exterior, C=Wheels P= OEM No,..Donor)
Thinking out loud, anyone fancy joining forces, and having a go with me...
Lordy. I was thinking that the other day! I thought I saw the brakes on an F came from the 800 series (may be wrong) the wing mirrors and interior door pulls come from the 200 range. See Karas flash new door mirrors from GW via ebay.
Discussion Starter #15
Thanks, I'll take a look,... thats more like.........but I wouldn't say a thing without my solicitor present.........:errx2::rofl:
I aim to please Mindy. I don't even hit the target some days though!
I know someone here fitted 800 series indicator/wiper stalks to his F not so long ago. I don't know if it is a straight swop though. I also suspect R75 interior door handle with the shiny chrome might fit an F mk 2 but these are non standard fits.
Discussion Starter #17
Rover 200 VI VVC engine, is it the same as an MGF ...??
just asking as seen somewhere.......
The VVC engines are the same, but with a slightly different gearbox ratio. Also the unit has mechanical power steering not electric so you have to remove the power steering unit. This is run from the alternator wheel, same one as the F, so its just a case of unbolting the PS unit and taking off the extra belt.
The has exhaust downpipe is different, but the VVC unit/manifold etc is the same. Clutch/Flywheel is the same. Dipstick has to be swapped for the crappy F one. Engine loom wiring is slightly different so that has to be swapped.
1 - 20 of 67 Posts
