rover_75
Just thought Id let everyone down under I was looking for a cheaper substitute for the infamous Texaco N402 auto transmission oil that MGR recommended which in Australia is like buying gold bullion (about $400 for a transmission re fill)
Called Caltex (Texaco) and it appears they do not bring that oil into Australia and that any suppliers who are selling it are getting it buy their own arrangements.
Caltex did state that they believed that while the N402 was cutting edge in its day,technology has moved forward and their new semi synthetic trans oil exceeded the N402 and was very close to the original specs listed on the N402 oil.
They also mentioned that Nulon (Australian oil company) appeared to have a fully synthetic transmission oil which tNulon claimed was a direct replacement for the Texaco N402.
I did a check and found that Nulon do advertise their fully synthetic oil as a direct replacement for Texaco N402.
I called them and spoke to their technical guy who reckoned the Nulon oil is fine to use in the Jatco boxes (Jags, Rovers etc) and even if mixed with the old oil,it will not cause any reactions.
I have bought some of the Nulon oil and will be doing a transmission oil change next week and will post the results.
rover_75
Discussion Starter #2
Just thought id do an update for us Aussies re the Nulon auto trans oil.
Car has run perfectly for about 7 months now so the Nulon oil appears to be a great substitute for the N402.
As a matter of interest also, re the odd sized thread for the MGR oil filters,rRepco make an oil filter for the Holden Colorado ,think it was the 3 litre motor, which fits the Rover 75 / MGZT 2.5 motors.
rover_75
Both my Rover 75 have been running on dextron II / Iv for around 5 years without any issues.
Any brand as Dextron is a specification.
rover_75
Discussion Starter #4
Your probably ok with that as it is used as a spec fluid on a number of other Nissan cars that used the same box.I think as it is new spec'd fluid it is probably ok.
The JATCO box running in the 75 did run at a hotter temp than in other cars and until recently the fluids on offer didn't do so well in a higher temp situation.
According to the auto guys Ive spoken to these days they are having all sorts of troulbe finding alternative oils for a range of auto boxes and do try a bunch of different oils in boxes to see what works and what doesn't due to the crazy costs some of these companies put on oils for high end cars. Its all got to do with the slippage the different oils produce,some work in some boxes and not others.All I can say is Nulons fully synthetic does state it is a direct replacement for the recommended Texaco N402.
rover_75_tourer
Jatco ATF & Texaco N402
I have a 2005 Rover75cdto Tourer Auto & have been researching an ATF replacement for MG Rover N402. Chevron used to supply it to MG Rover but also sell it independently. They no longer do the latter. However, Land Rover ATF 402 (sadly about £11 per litre & only sold in this quantity ) is the same product. Chevron now sell independently ‘Havoline Multi-Vehicle ATF’ and this can be used as a replacement for N402 & most importantly (because it is difficult to empty the Jatco gearbox) in combination with N402, so you can mix it with N402. Note that Dexron III is not the same as any of these 3 ATFs and on the basis of my investigations I advise against its use. I hope this helps.
rover_75
Discussion Starter #6
The nulon fully synthetic ATF oil does list it as a direct replacement for Texaco N402.I have run both my Jatco autos on the Nulon oil for the last 5 years and neither has missed a beat. I would also mention that a number of oils probably could be used but according to my auto specialist it is all down to the slipage each oil has,whilst it may appear to work under normal conditions,under load you may have issues. I beleive the auto guys spend alot of time working out what oils will work in particular transmissions before using it regularly.
