1 - 1 of 1 Posts
Hi all!
just got myself a MG TF and picked up a hardtop separately, it had mild leaks at first and the passenger window needs to be lowered in order to open the door - after moving the seals across slightly that seems to of helped with the leaks, they’re still there but nowhere near as bad as they were however the door not opening (when the window is all the way up) issue is still there.
I'm wondering if this is a seal issue or if the window needs to be re-adjusted?
The window does look like it goes all the way up (to the point where I can’t open the door) however there must still be a gap as water is getting in?
If anyone has had this issue and has any guidance I’d greatly appreciate it.
- Luke
1 - 1 of 1 Posts
