According to the exposure report, the new car uses a closed front grille shape, with double circular headlights on both sides, making the car look very cute. At the same time, a double C-shaped design is used below, which cooperates with the central flat trapezoidal air intake to add a bit of sportiness to the car. At the rear, the new car also adopts a cute design style. The round taillights are matched with the double C-shaped shapes on the two sides of the rear bumper, which form a clever response.
Car home
In terms of dimensions of the new car, its length, width, and height are 3140/1648/1521 (with shark fin antenna 1531mm) mm, and the wheelbase is 2000mm. In terms of configuration, the car will provide double-sided decals, black shark fin antennas, and various wheel styles depending on the model. In terms of tire size, the new car will provide consumers with choices such as 175/60 R13.
In terms of power, the new car will be equipped with a drive motor of the model TZ154XS1001 provided by Jingjin Electric Technology Co., Ltd. with a maximum power of 50 hp (37 kW). Yuan lithium-ion battery.
Source URL:
Cheers..
