Just put another soft top on and struggling with aligning it correctly. It went on OK but I cant close/open the door with the window fully up!!!!
Is there a special trick with this or is it just trial and error - minor adjustments until I get it right??
HELP - Its raining here!!
I have the opposite problem, my door glass doesn't quite reach the seal attached to the hood at the top/front of the window.
Is the glass difficult to adjust to take this space up?
Discussion Starter #5
omfg, I wish I never started this, just spent the last 90 mins adjusting, adjusting and more adjusting and still no better off....methinks its time for a trip to the garage!!!!
Yes, it can take a lot of trial and error - I raised and lowered the window so much I totally drained my battery doing mine. I left it as it was once I recharged the battery so still not as well aligned as I would like but seals OK.
I used the same "how to you" are following and although the instructions are excellent, there is definitely an art to getting it right.
I’m having the same issue the OP had, new hardtop, passenger window fully closes (but leaks) and I can’t open the door while the window is fully up.
Any advice?
