Status
Not open for further replies.
1 - 1 of 1 Posts
Super Moderator
Rover 200 Rover 600
I wanted to tidy up threads in this section which were all scattered around in order for members to have all useful information on one place.
If you find any useful thread that should be mentioned here, please give me a note.
https://forums.mg-rover.org/rover-600-121/drivers-window-464107/ - How to open, clean and repair windows switch pack
https://forums.mg-rover.org/rover-600-121/how-fit-%85-door-open-warning-lamps-doors-867445/ - How to fit door warning lamps in Rover 600 doors
https://forums.mg-rover.org/rover-600-121/rover-800-turbo-alloys-rover-600-can-you-help-242805/#post2527044 - Can you and how to use Rover 800 17" alloys on Rover 600
https://forums.mg-rover.org/rover-600-121/install-vitesse-recaros-into-620ti-815890/ - How to install Vitesse Recaro seats into Rover 600
https://forums.mg-rover.org/rover-600-121/rover-600-how-brake-guide-161736/
https://forums.mg-rover.org/rover-600-121/rover-600-make-your-own-vacuum-bleed-kit-161765/
https://forums.mg-rover.org/rover-600-121/how-change-front-discs-rover-600-a-185020/
Poor handbrake effort:
How to adjust cable Handbrake Help Pls - MG-Rover.org Forums
Rear pads, cable Rover 620i rear discs pads and Handbrake - MG-Rover.org Forums
Dirty caliper, thin pads 620Ti handbrake - MG-Rover.org Forums
Clutch bleeding:
Bleeding Ti clutch can't bleed my clutch - MG-Rover.org Forums
Rover 600 fuse listings
Rover 600 Service Intervals
Rover 600 OEM Tyre Sizes
Rover 600 'OEM' Fuel Consumption
Rover 600 OEM Fluid Capacities
Quick Fogs Guide
How to: Rover 600 - warm engine starting problems
Some useful threads on RoverTech.net (it's free to join):
600 series (any engine) - How to access/repair driver's (front) window mech:
Rovertech.net ? Login
T16 specific-How to change rad on a Ti:
How to change water pump on a Ti (this one's a sticky on RT):
How to fit door warning lamps in Rover 600 doors:
http://www.rovertech.net/forum/viewtopic.php?f=7&t=151941
1 - 1 of 1 Posts
Status
