rover_600
Hello,
when i click A/C knob, compressor clutch do nothing.(led indicator an the knob light up)
System have pressure.
condenser fan engages, engine revs. boost up. fault list empty.
compressor clutch engages if forced (manually). If trinary switch is disconnected engine revs. wont boost up.
Does anyone have any idea what the problem might be?
Thanks.
P.S. electric schematics would be welcomed.
rover_600
Discussion Starter #2
Oil pressure sensor... It turned out that oil pressure (near oil filter in L series) sensor gave way and blocked incoming signal from compressor clutch relay.
As i looked for original part I found just one seller in ebay for 60 pounds (item+ postage). does anyone knows generic manufacturer of oil pressure sensor ?
