Hi
can some one help me out have a old rover 45 diesel 2.0 l serial i have a etc code p1218
not to sure if its the Injector fault
or point me right direction
Darren
Discussion Starter #2
Hi me again for got to say car will start and run ok but will take a good 30/40 sec to start
mg_zr
That error is due to the failure of the pilot injector, check the plug and the wiring and with a multimeter the resistance, it must give you values above 80 (at least mine give those and do not give failures), if the problem is internal to the injector I think the only solution is to change it.
Enviado desde mi Mi A1 mediante Tapatalk
