Looks like I need to build a new engine as I've got excess crankcase pressure problems.
So I'm after a good T16 turbo block please. Bores can be scored so long as it isn't very deep (as they'll be rebored +0.5mm)
I've also got a new crank so again not too worried about that bit either.
What have people got lying around?
I've got a 55k T series NA block available if that's any use? If you're reboring, presumably you already have pistons you want anyway, so you'll be swapping? Otherwise, the blocks are the same.
You'd need your sump for the turbo oil feed return, but that's it for differences.
I'm based in Manchester (I used the head for my own T16 turbo).
